Scott Baret
I'm having some issues with AppleTalk on a few machines.
Both are re-capped, so we can set that issue aside right now.
The first is an LC. This one has never worked on a network, even with its original board. (I'm not sure if the original board was the one I got re-capped or if I put another one that had already been done inside).
I've tried a lot of different things on it, including a new PSU, a different box, a fresh system install...and it just won't see the network.
I have a Classic II that does the exact same thing.
I swapped out LocalTalk boxes themselves. No dice. I also know the box I used works; I was able to use it to join a known-good Classic to the network.
They don't see servers, ImageWriters, or other computers. I also dug out my LaserWriter to try with tomorrow, just in case.
Is it boards or something else?
