Hey all,
Interesting issue I have here, as I've obtained PowerBook 3400c/200mhz - The shift key is depressed constantly - I haven't pressed it at all, I've swapped the keyboard over with another 3400 keyboard that is working to eliminate keyboard issue.
Disconnected the main keyboard, plugged in ADB keyboard in - same thing!!
What would it be caused by to have the Shift key depressed?
When you start it up, extensions is disabled due shift key is depressed - so its not software issue.
You cannot use the trackpad to open apps etc due depressed shift key.
Recap issue?
Cheers
AP
Recap issue?
Cheers
AP
