My Hyperdrive doesn't work right now, I suspect a bad capacitor on the daughter board and the old MFM hard drives... That reminds me, I need to sort this thing out quick. It's been sitting in my living room for nearly a year.
Does it have a daughterboard or not, I wonder? Since it uses SCSI and not MFM (unlike the Hyperdrive), there are no extra circuitry required on this one, I think...
I know you can tap into the power supply to get +12V and +5V to power the drive itself.
Someone (it might actually be you mactjaap...I don't remember) linked a picture of a hacked Plus with an internal SCSI hard drive. The job looked woeful but seemed relatively simple...
Looks great! A quick Google search reveals lots of pages about a Symbiotic hard drive for the Apple II. Haven't found anything about a drive in a Plus.
I like that it has the pass-through SCSI. You could get one of those SCSI ports that fit in the battery compartment. That'd give you TWO external SCSI ports.
So now I get it. There's a cable sticking out of the back (probably through the security slot) that connects the hard drive to the SCSI port.
I bought a Plus ED, which I'm sure you're familiar with, mactjaap, since it's from the Nederlands ;D . I plan on adding an internal SCSI drive to it.
It doesn't work right now, but I'll fix this guy sooner or later. Need to order some caps now.
Could you please take a picture of where the molex connector wires originate from on the analog board? I think I have a pretty good idea of where to get +12 and +5, but since I'm not an EE at all, I don't want to risk hurting my Mac too much
It literally looks like a regular external rodime stuffed insie the plus. I have a rodime and a half lol no top case on the second, both still work and it looks just like that.
Here is the best picture I could make for connector wires. I hope you can use it. I'm afraid I have to dismantle the harnas to get better ones.
How nice your bought a ED from the Netherlands. I helped a fellow forum member to export one to. Here you can find them quite often. ( I have one too )
