I'm surprised, I'd figure you of all people would be enticed by pulse-length encoded analog video on optical discs. Plus LD allows the operator a surprising degree of control over the actual transport mechanism.
I had a similar issue with my CD SC and it turned out to be CD format related. Basically the larger 700MB formatted CD-Roms or CD-Rs did not read (CD-RW never work on some!), but I found that earlier Apple CD-Roms that came with both MacOs 7-9 and Mac OS X formats, loaded ok and did not eject immediately. Can't recall which of those grey Mac CD's it was, but I recall it was a real early disk (maybe a Airport CD Install disk or something?). I then found some commentary that suggested that these earlier Caddy CD drives came out when 650MB CDs were the thing and thus can't read the newer/faster/larger CDs. That said, seeing it reads ok then ejects, sounds like optics or wiring (heating up, separating)?Drive #1: about 80% of the time, it ejects the caddy immediately after putting it in. If it does keep the disc in, it reads it normally without errors, but sometimes spontaneously ejects it several minutes later (whether active or idle at the time).
I'm having similar issues with newly recorded CDs, but not with older recorded (I have some from the 90s) or purchased CDs they insert and read fine. I'm wondering if the drive has less tolerance than newer drives, e.g. the 0s and 1s aren't as defined anymore.Resurrecting this thread to ask about a closely related set of symptoms: I have two Quadra 650's that each came with an internal CD drive (Sony CDU561-25), each of which has different problems.
Drive #2: when I got it, it would load the disc but generated frequent read errors and very slow data rates (probably retries). Now I just hear seeking noises while I get a spinning cursor, and after a few minutes I'll get a "disc unreadable" message.
My first thought was bad caps, and actually the boards are quite a mess of cap goo. I've recapped and thoroughly cleaned one board (not the other yet). But here's the funny part: both problems above follow the drive mechanisms, not the PCBs. Each drive will behave the same whether it's got the recapped board or the non-recapped one.
Earlier in this thread, techknight says that weak optics might cause the eject issue. I've cleaned the lens with alcohol on Drive #1. It still ejects discs 80% of the time but I haven't seen a spontaneous eject after the disc was loaded. I haven't tested Drive #2 again yet.
What else should I be checking? Are there other parts under the lens to clean, and if so, how do I get at them without damaging the mechanism?
Sorry for bringing this thread back from the dead, but do you have a copy of this software? I need it for my AppleCD SC.Thanks techknight!
I guess next thing is to try it out. Got the software. All I need now is my SE/30
Will report back next Saturday.
