3D-printed Casing for LCD Panel?
ktkm
Hello,
I bought this display on ebay, since I sometimes want something less bulky than a 13" CRT to hook-up with my IIcx. It arrived last week and works just as promised. But it would be nice (and practical) to design some kind of casing that better mimics the Snow White theme?
Suggestions on how to pull this off is truly appreciated!  :)
/Kristian
I'd say shoot for a tone in between the two, but closer to platinum. You'll NEVER get a perfect color match without paint and even that's difficult aside from the irritating fact that all computers are a different tint of the color platinum or fog or beige or whatever came off the injection molding machine at birth.
See if you can crib some design cues from this cute little number  .  .  .
.  .  .  .  which was borrowed for the Teddy Top project and is available there for download.
You've caught my fancy with this notion, I've got some 3D images for an LCD in Faux//c case hack flipping about in the back of my head.  [:)] ]'>
What might work is buying an Apple CRT (preferably a non-working one), then just using the front bezel.  You'd then only need to worry about the rear of the LCD panel.
Front bezel is the easiest part and flat, no curvature correction necessary. LCD correctness would be the point of going with the IIc panel model.
One problem is that it wouldn’t fit neatly to the front due to the curved CRT opening.
You've caught my fancy with this notion, I've got some 3D images for an LCD in Faux//c case hack flipping about in the back of my head.  [ :)
I think you’re right. Grey and halftones are the hardest colours to match. Probably best to leave color out for now.
I agree.
Thanks for link!
Well, you may not need to 3D print anything.  If you get a piece of plastic, you could CNC mill it for a lot less.  Then paint it.
I found my plexi bender. Gotta see if it works. Really old school from long before I finished up my apprenticeship in a 50 year old sign shop. It's got the period correct asbestos bed and everything. Still not friable, so it's safe enough to keep around. I'm hoping the heating wire is still good.
I need to see how case corner bends look when bent on a routed V groove. The pet IIfx is going to have a customized clear lid lavished upon it one day. I'll be practicing on Compact buckets in the mean time, gotta love all those complex bends. [:)] ]'>
No logos involved for either project luckily. None on the Compact buckets and none on the IIfx topper. The IIfx will have a wider "floppy" groove for Zip compatibility behind what's now a cover and the side will have a slot for my stealth trayloader hack  .  .  .
/monthly_04_2017/post-902-0-53402100-1493229354.jpg">IIfx-ClearLidHack-01.jpg
.  .  .  finished this post in the original thread, had to re-post the AWOL piccie anyway: IIfx-ClearLidHack™
Well, I’m back after some modeling in AutoCAD. Next step would be to mill or print? I’d really like to come in contact with someone who has done this sort of thing before and could give me some exclusive advice.
If anyone would like to try printing or milling (no guarantees)? Please help your self to the .STL files!
Thanks,
Kristian
Monitor_chassi.zip
Thanks! I’m currently working on the kickstand but I think it would require a VGA ribbon cable of some sort, any ideas where to find one?
Use ribbon cable and solder cup terminated HD-15 connectors. You might want to use a bit wider cable. Dunno how it works out, but make sure you've got alternating ground lines between all signals.
p.s. don't forget the Snow White grooves on the backside. ;)
edit: you might want to consider burying the the cable and VGA adaptation inside the case and running the ribbon to a DA-15 connector for the Mac Also, if you can find the twisted pair version od IDC ribbon cable, it may help with the RFI antenna transmission aspects of exposed ribbon cable.
