My Mac SE/30 has a white spot on the top from something sitting on it. Its also a shade of yellow... along with the keyboard and mouse.
How do I go about retrobriting it? I know the actual product, I mean taking the thing apart!
The back case is easy enough to get off, just the four screws. However the front part... that looks tough. I was hoping to not discharge the crt, however it looks like I may have to..?
The keyboard just has the screws on front and back, and I think the keys pop off? Yes, I know, be careful of the space bar spring.
The mouse has a few screws, should be easy.
I am worried that the retrobriting will eat away at labels. Not the pop out pins (taking those out) but like the back SE/30 sticker and the front label that says Macintosh SE/30... will it harm anything? Or what about the grey paint inside the back of the case?
Would gel be better since the back of the case is so big???
Thanks for your help!!
