VidCard Rosetta Stones? DA-15 <-> DE-9 <-> HD-15Translations?
Trash80toHP_Mini
NIGHT STALKER
68040
Not sure if I've ever posted anything as a conquest, but I think this one truly fits the bill.
When I saw that breakout board my VidCardAholic chip dropped back to newcomer again on a one day binge. I don't even have an SE. :I
I'd snagged this one on a $12.99 BIN without even noticing the unpopulated thruholes. That was just to play with Radius' mysterious DE-9 interface to the early Radius FPD monitor dreams of Fontographer/Illustrator grandeur for my SE/Radius16 when they were new and financially unobtanium. I figured I could noodle it out without buying an SE or a Radius VidCard.
Next week can't come soon enough! :D
It looks like my OP was about as cryptic as usual, maybe more so? Whatever, lets try it with some more on point visual aids.
Here's why the SE Card is so important, the interface between VidCard and breakout panel board is a 16 pin IDC header cable. The DA-15 will hopefully have the bog stock Apple spec pinout. With a little continuity testing and a bit of luck, I'll have the mysterious DE-9 Video Interface from the stone age of Macintosh Display Technology figured out.
Since I haven't even got an SE for testing, the first card I snagged on a lark was intended to explore DE-9 VideoVoodoo with the IIcx. It turns out this NuBus card may very well be much handier than I'd hoped.for a second reason.
Note the unimplemented HD-15 thruholes next to the DE-9 Connector! VGA and its HD-15 connector were introduced by IBM in 1987, three years before this ©1990 NuBus Card. So I've got two chances at finding a conversion table from the ancient DE-9 video interface to a documented VidCard interface from a more recent era of Macintosh Graphics Cards.
The listing called this an Apple Card, we'll see when the results from DeclRom spelunking are in. I'm guessing it was made by a third party unconnected to either Apple or Radius. I didn't see any info on the development dates for SVGA or XGA in a quick search, but it stands to reason that a VidCard mfr. might have doubled down their bets by supporting both the then standard TPD interface and emerging Video Standard technologies
We shall see.I know olePigeon and a few other folks here that will be very interested in any results that might be forthcoming. [:)] ]'&gt;
I have a Lapis card for the SE I snagged right before Christmas that has a similar breakout board to DE-9 and VGA.
Like olePidgeon, I wanted it to figure out how to get video out of the headless MicroMac SE chassis' we picked up.
Nice thing about the MicroMac/Lapis card that came with the chassis is that there is a passthrough to plug the accelerator card on top. This is missing in the straight Lapis card.
I can send you some pics of my card as well in a day or so, or even send it along if you want to try and buzz it out. That's what I was going to do :)
Very cool! Just send pics of both sides of the PCB. Buzzing it out is easy, we can compare notes after I get mine figured out. [:)] ]'&gt;
Color me jealous re: you guys scoring those beasts, now that was a conquest! I'd love to see HiRes pics of both sides of every board in those puppies.
I've got another one on the way! No Rosetta Stone translator connection on this board. However, it's the perfect translation test for the Compact Mac FPD/TPD cards listed on eBay and already in the hands of many comrades here  .  .  .  and no SE required!
Not to mention that it's yet another NuBus gem for overflowing Plastic Storage Drawer of Radius Treasure!
p.s. the first two VidCards are on the truck out for delivery very soon now! [:D] ]'&gt;
So... perhaps of interest. Did any of those cards actually output to both connectors at once? All modern video cards turn off a port when they do not have anything connected, and I believe that even, say, if you had a bunch of Tobys in one Mac II, it wouldn't activate the port if there was no monitor attached. (In fact, some people used VGA adapters on servers so a machine would believe it had, say, a 640x480 display connected, so they could easily VNC/Timbuktu/whatever or if there was a Mac model that would not finish booting if there was no display attached.)
If not, there may not be a whole lot that can be gleaned simply from having a card that has both, unless you have a Radius FPD that you can connect, then unplug even though the machine still thinks the monitor is there. At that point, you don't really need a card with both.
You misunderstand, we don't need to add connectors for the second port at all.
It's the traces on the dual connector cards leading from DE-9 connector to unimplemented thru-holes for the second connector that are of paramount importance. Visible and buzzed connections will hopefully lead to determination of the signals present on the DE-9 connector's pins. DE-9 appears to be in common to all but the BNC versions of Compact Mac VidCards predating adoption of DA-19 as the standard Macintosh Video Interface. This certainly does not mean that all DE-9 interfaces are identical, but we've had absolutely nothing to go on up until the discovery and acquisition of these three Rosetta Stone cards by ScutBoy and myself.
I'm totally burnt out from seven straight hours of testing and swapping components around in the first six victims from the 27" 1400 stack. I'm getting dressed and heading over to the rental office right now. We shall see what transpires! [:)] ]'&gt;
Let's take a step back here:
Radius was founded in May of 1986 and run by the best of the best of the Macintosh Development team. Their knowledge of the inner workings of the Beta release 128K, the 1.0 release 512K and the four months previously released Macintosh Plus was matched by no other Macintosh developer.
&lt; quote &gt;
The MDA did not have any pixel-addressable graphics modes. It had only a single monochrome text mode (PC video mode 7), which could display 80 columns by 25 lines of high resolution text characters or symbols useful for drawing forms.
&lt; /quote &gt;
The Hercules Graphics Card (HGC) was the first bitmap addressable standard in the PC world. I ran them back in the day, like MDA and CGA it was a TTL output signal. Heck, If I were at Radius at the time I'd connect my monitors only to the unused pins of the MDA interface to ensure containment of the magic smoke!.
&lt; quote &gt;
The first Radius product was the Radius Full Page Display, the first large screen available for any personal computer. First available for the Macintosh Plus, it pioneered the concept of putting multiple screens in a single coordinate space, allowing users to drag windows between multiple screens. This was a concept that Apple later incorporated into the Macintosh II.
&lt; /quote &gt;
Early FPDs/Cards used a one BNC interface carrying an analog signal driving a 640x864 pixel 8 1/2" x 11" WYSIWYG page as compared to HGC's 720×348 pixel output.
GREAT Radius FPD writeup: http://32by32.com/radius-full-page-display/
edit: and now to open up the two boxes I picked up this afternoon! [:D] ]'&gt;
Just psyching myself up for the next delivery! [:)] ]'&gt;
Haven't unbagged the Radius NuBus TPD Card yet. I'm way too tired, that's for tomorrow when I set up the copy stand to document both cards. However I did give the Lapis Technologies DisplayServer Output Board for the SE Card a quick going over with the continuity tester. Looks like all the cable signals except what appear to be power and ground lead to the DE-9's pins and then just two travel from there to the DA-19's pins. Both are resistor limited and I'll have to compare to the DA-19 pinout tomorrow morning when maybe I can see straight again  .  .  .   :blink:
edit: found a great article on the Lapis Display Server that confirms my suspicions. Also found avadondragon's
Lapis Technologies SE-DPD video card info? thread from last year while searching, great info there as well.
In my ferenzied 1400 marathon induced state of frazzlement last night, I totally missed that bit about Jim Harris, co-founder of Lapis Technology having been a former president of Hercules.
EGA/VGA compatibility neatly explains why there are so many traces leading to the DE-9 connector on the SE breakout board. After I wake up the rest of the way, I'll noodle out the signal the comparison table. On the first pass after one cup of coffee, my WAG would be that the DE-9 connector is TTL EGA and the DA-15 is the Macintosh Video Standard that's convertible to the HD-15 analog VGA standard.
We shall see. Now I do wish I had an SE and an EGA monitor. If my WAG turns out to be the answer to this pinout puzzlement, does anybody have an SE + EGA combo in their collection for testing?
It's sort of unclear to me what your intent was here in breaking them up the way you did but just FYI/to be clear, "Hercules" and "MDA" are *not* different "video standards" so far as the physical interface went. MDA was limited to text only because it only had 4k of RAM on the board and no method available for filling the output shift register with anything but dots from the hardwired character generator; a Hercules card is basically just an MDA card with a massive RAM upgrade and a few tweaks to enable graphical output and uses exactly the same monitor. (Which was in fact the whole point of the card.)
Anyway, a couple more notes about the "9 pin standard" so far as it applies to PCs: All three 9 pin TTL video standards, MDA/HGC, CGA, and EGA all use the same pins for vertical and horizontal sync, pins 8 and 9, and all have a ground on pin 1. How many of the remaining pins are wired is your best clue as to what standard the card you're looking at is designed to support; if it has 7 (and optionally 6) connected there's a reasonable chance it's MDA compatible while if *all* the pins are connected it might be EGA...
However, when you're looking at something like an oddball video card for something like a Macintosh that happens to have a DE-9 connector on it, all bets are pretty much off. Even IBM misused the DE-9 connector on the completely incompatible with anything before-or-since "Professional Graphics Controller", which used a VGA resolution analog RGB monitor with composite sync, early Multisync monitors often had unique 9-pin pinouts that required their own cables (NEC's Multisync and Mitsubishi's Diamondscan lines were an infamous example), various full-page display vendors might use whatever pinout they felt like for their proprietary monitors... etc. I'm really not sure you're going to learn a whole lot useful by staring at the traces on these adapter cards other than *possibly* getting an idea of whether a given card uses IBM compatible TTL sync or... something else (*).
(Note: VGA uses TTL sync that's electrically compatible with the sync signals of the older IBM video standards, although of course it's running at a different rate. So, well, I guess you may well learn something if you find that on some multi-monitor compatible card that has both 9 pin and VGA connectors if there's traces between pins 8/9 and 13/14 on the two ports respectively; the thing you will have thus learned is the 9 pin port *is more likely than not, but far from definitely* indeed for something like an MDA monitor. For whatever good that does you.)
The early 9-pin NEC Multisync (and some other early RGB monitors) used the PGC pinout for analog RGB input before VGA's HDI-15 showed up. See attached file with a nice "decoder ring" of early video standard pinouts. The only one that is missing is MDA, but its similar to CGA minus the R,G,B channels with video on pin 7.
CABLE.HTM
I'm aware that Hercules was an MDA-compatible monochrome graphics standard developed by Van Suwannukul for the special purpose of displaying the Thia Alphabet on the PC. You may poo-poo it as being just MDA with a lot more RAM, but it was a groundbreaking achievement. Having used Hercules Graphics Cards for running CorelDraw back in the day on a Page White TTL monitor, I can say Hercules was more than enough differentiated from IBM's MDA to consider it a separate standard.
Check out the InfoWorld article above for the information supporting my EGA connector/DA-19 Mac -&gt; VGA WAG. The breakout card has 6 distinct traces heading to the DE-9 connector with two pins tied together from one trace. The last two appear to be tied to ground, including the Square pad and the pad adjacent to it. I'll post pics of my Rev.3 DisplayServer breakout card this afternoon. In the meantime, the pinout/traces are pretty clear in the enlarged section of the listing pic in the second post.
I haven't searched the socketed XILINX part at U2 on the main board yet, but my guess has been RAMDAC.
The second photo of the NuBus card caught my eye. Those solder bridges labeled "ECL" in particular. The card might be using the rather obscure ECL video standard that the Atari TT used for it high res video modes. Some info (and a convertor) here: http://www.tenox.net/hw/tenoxvga/
Pinouts (9-pin): http://old.pinouts.ru/Video/ecl_pinout.shtml
ECL = Emitter Coupled Logic
Used by old Sun, Apollo workstations along with the Atari TT..... and maybe old Radius displays.
