2400C-Does Anyone Recognize this Password Protection?
I just picked up a "non working" 2400c from a recycler on Ebay that booted right up as soon as I powered it on.
Unfortunately, it looks like the OS is password protected. Does anyone recognize the password protection program, and if so how to defeat it?
I'm a bit "stuck" on this one, since I don't have one of the PB SCSI adapters(I REALLY need to get one) so can't connect a CD-ROM drive or use SCSI disk mode-I'm going to have to pull the drive to do anything.
No luck with extensions off.
The password window comes up before the splash screen. In fact, if I hit "cancel" the Happy Mac flashes briefly before the computer shuts off.
Best bet is pulling the drive. It's IDE so hooking it to something else shouldn't be much of an issue.
That's the current plan. Hopefully I can dig up a 44-pin to 40 pin so that I can look at it in a desktop since that's a lot easier than putting it in a laptop :)
Granted I have a couple of USB bridges, but I think they're all bus powered and sometimes don't have enough juice to spin up a full height drive(or a 7200rpm).
Hopefully there's SOMETHING I can delete. Otherwise, I'll dump a fresh 8.1 install on it.
Here's the password: "s7AL4#hk"
I just called the number, told the man on the phone I had bought the laptop and he gave it to me.
Thanks for doing that-I should have tried it!
In any case, apparently he doesn't remember correctly-that doesn't work!
Thanks!
I though it did look familiar.
Unfortunately, like I said pulling the disk is my only real option now as I don't have a PowerBook SCSI adapter. I've gone a bit nuts on OWR and 68K PBs lately, so that's something I REALLY need to fix.
A CF adapter also seems like it would be a good investment.
Alright, I pulled the drive which actually surprised me in that it was half height rather than full height. I'm use to working on 3400Cs and Kangas, but then the 2400C is a LOT smaller. It's also not the easiest hard drive I've ever pulled, but it does beat the heck out of an iBook(any version) and 12" G4.
In any case, once I got it out I was able to run it through my USB bridge fine. I attempted to modify the password file as described above, but in the end just nuked it. Fortunately, the computer booted right up.
I also got the pleasant surprise of finding a 64mb memory module for a total of 80mb.
It's running OS 9.1, which is not my choice for something with 80mb of RAM, but it does seem to run it well.
That name looks really familiar for some reason. I feel like I know someone by that name but I can't remember from where.
Interestingly enough, I had a PDQ that I'd lost/forgotten about and when I booted it up, I was greeted with a very similar screen.
Fortunately, I had bought this computer from its original owner. He was kind enough to provide me with the password when I had bought the computer, and I was able to dig through my old PMs on MacRumors and find it.
The password is simple and easy to remember, although just in case I forget it again I've put a mailing label on the bottom of the keyboard. I don't want to nuke this one entirely as it's nice to see a classic OS 3rd party security system intact.
That's the standard Apple Protection for the powerbooks on System 7 & 8 (which is rarely used). I have set up on my 5300 and G3 Wallstreet.
The password is in an invisible file in the System (I think System Prefs). Delete it and the extension preferences and it will boot up without a password.
