Howdy!
I am in the process of restoring a Macintosh Portable (5126) I recently picked up from a former Apple employee. Taking the advice of the forum, I immediately rebuilt the battery with new EnerSys Cyclon X cells and replaced all of the capacitors on the logic board. The leakage and corrosion was fairly extensive, especially around the large axial cap near the sound section.
When assembled and tested (with original AC adapter and rebuilt battery), the portable powers up and appears to work properly, however, the floppy drive makes a constant low-pitch whine (there is an unknown disk in the drive) and the hard disk appears to do nothing. The portable posts to the blinking question mark.
There is also no sound from the speaker. I have yet to check the headphone jack.
I suspect a power issue. Are there a couple of components I should check first? I recall some corrosion near the LT1070 converter.
