Problem is I don’t know if my OrangePC card is able to read devices on the SCSI bus. I asked that in the previous post. Still waiting for confirmation on that.You'd have better luck copying the win95 directory from an install cdrom to the partition
I wonder if the 68040 requirement is artificial.Connected my “new” 1.2GB Quantum drive to the IIfx. Although it works, there’s a lot of stuff on it. I tried transferring said stuff to my 9GB Avid/Seagate SCSI drive, but I get this error when I try to mount the drive in SCSIProbe:
Is there a way to update the drivers on the 9GB drive without reformatting it so it works on a 68030? I tried Apple’s HD Setup but it doesn’t see the drive at all.
ParallelSerial and/or parallel?
I’ve been looking for the breakout cable for this card for over 4 years now. I’ve been told several times by other members they are made of unobtainium.You can easily transfer files that way with the appropriate cable from another pc
I’m using that slot for my SB-2770 card, so I have sound in Windows.I saw an ISA slot on the first page
Only way to do that is through the SuperDrive, unfortunately.Can you transfer files from the Mac side to the OrangePc side directly?
MS was really cramming in the data in those days lolDMT format with a capacity of 1.68MB iirc.
Not sure. AppleTalk did the job, albeit slowly.I wonder if the 68040 requirement is artificial.
Not with the OrangePC software, no.You can't mount a Windows CDROM?
It was never determined which exact model of OrangePC card I own.Which card are we talking about?
Unfortunately, I don’t have Win 95 on CD. Just the upgrade floppies.with your Windows 95 CD
