Pinnacle microMotion DC30plus
What do people know about these cards? Does anyone have a copy of the software that came with them?
The manual (attached) says they're for G3s and G4s, for use with Premiere and Final Cut.
I feel like you see them quite a lot, were they an option from Apple directly?
Were they used with any other hardware? Or is the cars everything you'd need?
I have a card, but am missing the audio breakout. Does anyone have one, ten minutes and a multimeter?
I was sure I had seen this one before while I was initially trying to sort what video card I could like trying track down (which atm has been shortlisted to just targa)
looks like it pretty much works in anything that has pci considering any(afaik) ppc system needs 7.5 at minimum as well
(and looks like you don't have to archive-link to the osx version atm but mm)
The manual for the plus says a G3 and 8.6. I'm sure you could get away with a high end 604, but the plus has significantly more throughout than the older version so probably needs the higher spec because of that.
Well, I missed that page on Mac Garden because my cards are all branded as Pinnacle and I misread Miro as Micro.
Isn't Targa stuff notoriously difficult to get working because the serial number is tied on a card by card basis to the hardware? If it is the card I'm thinking of you need to get the serial with the card. Might be something different. I have one, you can apparently do stuff to work around the restriction and I meant to do it as a project but haven't got around to it yet.
