Mac SE/30 Display Suddenly Wonky
powellb
Over the weekend, I left the Mac SE/30 running for #Marchintosh, but came to it this morning and the built-in monitor has gone completely strange. First, I could only see a picture when turning the front (and interior) brightness settings to max for both; whereas, it used to be normally adjusted. However, the display itself is now stretched ridiculously large in the horizontal and less so in the vertical. I have attached a picture of what it looks like now. Adjusting the pots on the logic board shows little to no change on the display.
I recapped and reflowed the analog board 18 months ago. I recapped the logic board before that. I also put in a Babyface power supply a year ago (my original Sony PSU is recapped and fine also).
I thought maybe the CRT gave up the ghost, so I swapped in another Samsung CRT I had from a scrapped Classic. It is behaving the exact same, so it isn't the CRT. I inspected the analog board and could not find any issue (flyback transformer isn't cracked and the main bar is solid). I typically use a video card from zigzagjoe as my main display, and that is working just fine. It is only the internal display.
Any ideas on what could have gone wrong? A failure somewhere on the analog board I am assuming, but I don't have the expertise to independently figure out the diagnosis of the CRT signaling.
I have been working trying to figure this out, and it seems that something is amiss with the "width" control circuit. The width adjustment is a coil within a plastic tube. When I put a metal hex driver in there to turn it, the screen width gets much smaller, and I can adjust it. However, once I remove the small hex driver, it immediately reverts to the image above. Additionally, the hex driver is far too hot to touch.
I recall reading years ago of people using small metal objects in there to correct it, but I would like to know what the issue/correction is. I imagine that component is now unobtanium (other than recover from other boards).
Any ideas on the width control circuit? The capacitors connected were all replaced as per above during the recapping.
You are correct, but I had no choice. The horizontal control is different than others in terms of voltage danger (still don't do it), but rotating the coil to set it with my plastic tool was having no effect. So, I inserted a metallic to see if that might be the cause (from some old CRT tidbits I found), and it had a profound impact, almost correcting the display to where it should be.
So, it confirmed that the horizontal driver is at fault, but I still can't figure out why/what is causing the fault...
Sorry, just saw your post.
any progress on this? Having the same issue on one of my boards.
Sorry, just saw your post. I am confident (not 100%) that the L2 slug inductor has internally broken (weak ferrite coil), so nothing is controlling the horizontal width. I removed and tested the resistors and capacitors tied to that circuit with everything in spec. I actually recently ordered a cheap Mac Plus analog board that was somewhat parted out to see if its inductor is any good and can be swapped in.
I have searched the web for any possible modern (or substitute) replacement for that part, but it seems that all manufacturers would have specific inductors for the driving circuits, so it seems the only possibility is to find one from a donor board.
I mostly use my external monitor, but the mac still sees the internal video as an option and some things (MacsBug I'm looking at you) will only display on the internal monitor. If I can't get this horizontal drive fixed, I might need to find or develop an extension that makes the system think there isn't an internal monitor. Then, I would just disconnect the CRT.
