FoxxConn Ribbon cable
Hi,
Might need more info - did you tear yours? The replacement would probably be finding a cheap Intel Mac mini over finding the specific part number, they're super cheap complete.
It’s not ripped, it only needs to go back in that slot. Is there a tool made that helps to put it back in?
Got it in once after about an hour trying for it to only stay for about 5 minutes.
This reminds me that I have one (my first, bought for Christmas of '06) in pieces because the nylon screws for the heatsink broke. I sort of remember something being wrong with that interconnect cable and the cooling fan, too.
Before that happened, I had it set up pretty well; back around 2015 or so, I upgraded it with MacMini2,1 firmware and a C2D 2.33 GHz CPU so it could run Lion. Because of the faster CPU, it felt somewhat faster (and because it could now run Lion, which was only just then falling out of support, safer), but it was still pretty slow by 2015 standards.
I should dig it out from wherever it is and get it put back together. By now, it could probably run Mavericks or even Yosemite or newer via OCLP, but probably at the speed of a melting glacier (which, climatologically speaking, is tragically fast, but still mind numbingly slow in terms of computing).
c
I have a few just trying to repair this one.
The first photo has the flat edge ribbon going into a slot. Was there ever a tool or an improvised tool to get the ribbon into the slot and make it stay there? This is the Core Duo Mac Mini.
The second photo has the snap in connector and is much easier, no tool needed. This is a Core 2 Duo Mac Mini.
Ah, that connector - usually small fingers :) or maybe a piece of cardboard under the brown sliding part, push ribbon back in firmly then push brown plastic down to lock it in. They are not rated for repeated use, I've been known to have to tape some ribbon cables down to get them to fit securely before.
