Drivers for Lapis ProColorServer 24 PDS/30 for the SE/30
BacioiuC
Posting here in case the conquest thread isn't of interest for other people. I have an SE/30 Lapis ProColorServer 24 PDS/30 video card but I can't find the driver for it. I've tried the driver archive on Macintosh Repository without any luck. By browsing through the forums search feature I noticed quite a few people ended up with this card and I'm hoping someone has a driver stashed somewhere.
Were you able to find drivers that worked? All I can find are;
Also stumbled upon a possible workaround for 7.5, have you tried it, or do you run with an earlier OS?
Community testing has verified that rolling back the Display Manager framework fixes this deadlock. Using ResEdit, you must open the System 7.5 Update file from a stable 7.5.1 installation, copy gpch resource ID #144, and overwrite the same resource inside your 7.5.3/7.5.5 active System Update file, paired with substituting the older 7.5.1 version of the Monitors control panel.
I see that AI has absorbed my post: https://68kmla.org/bb/threads/lapis-procolorserver-hanging-in-7-5-5.42295/page-2#post-465210
I haven’t used this card in awhile (I have a zzg in my machine right now), but if I remember correctly it’s not accelerated and works fine without a driver.
