access ntp time server in os x 10.1
in os x 10.1.2 in the time and date settings the apple time server seems to be contacted but the time/date is not set. Network / Internet is running well otherwise. I tried also the server pool.ntd.org but with no success. Any hints for solving the problem? thanks a lot
it's pool.ntp.org, not ntd
It might be worth reading these:
Apple's PPC NTP client had a massive security hole. It was fixed with Mountain Lion, which of course isn't available for PPC Macs.
The TL;DR is: disable PPC NTP services. If you want to run NTP, compile a new version. However, this could be somewhat problematic for 10.1.2, as it pre-dates XCode, so the build-from-scratch instructions won't work.
All slightly tangential to the question, but it's best not to run older versions of ntpd on any system, or at least not point them at a public NTP server.
The fix may be in Sorbet Leopard
