Iisi issue
Feeling lazy tonight lol.. so picked up a iisi logic with rom simm slot. It has rom on board as well. It is recapped, nothing major that i could see. It turns on, chimes and then gets death chimes. Screen comes on for a second when first turned on, then nothing, stays black.
On a side note: will an apple se/30 rom simm work in the iisi? Thanks for any info, and excuse my laziness in searching!
Might be bad ram.
SE/30 rom won’t boot a IIsi.
Will iivx onboard ram be the same? I assume it would be. I also have a spare classic board around and a duo 210 board.
IIvx has 4MB onboard (512k per chip) so is not the same since the IIsi has 1MB.
The Classic has the same 1MB onboard (128k per chip).
FYI you can upgrade the IIsi to 4MB so you could use the IIvx as a donor if you change all the chips.
So on the Mac IIsi there need to be a jumper on W1. This will disable the onboard ROM and allow the use of the ROM SIMM
Is your ROM SIMM a genuine Apple ROM or Custom ROM?
He doesn’t have a rom simm, he said it is onboard.
Oh interesting. So i do have a donar iivx board. So can definitely upgrade the memory
Yep. Not saying it’ll fix the death chimes but since you’re changing chips anyway you might as well upgrade.
Some discussion here:
Oh ok, i remember that thread now. I actually commented on it lol.. so yeah will see.
I re-read the thread and Zane (the OP) was saying he doesn't recommend the mod, as it reduces performance if using onboard video. Bank A which the video uses is performance constricted so it's better to keep it to 1MB. You want all your apps to be in Bank B.
I had exactly this issue with one of my Iisi boards.. turned out to be one of the oscillators.. I think G4?
Replaced g4, no dice. Tried replacing one memory ic no dice. Guess i will have to try them all and see. Argh! Lol cant find my spare classic board. Will any of these chips work?
Did you already swap in all the RAM from your IIvx, upgrading it to 4MB?
If so, you can use the 424410 chips (because they are 4 bit chips) but not the 424100 chips (because they are 1 bit chips). Eight chips need to add up to 32 bit (the width of the data bus) hence you need to use 4 bit chips.
Otherwise, your IIsi still has 1MB onboard and neither of these chip types is suitable. You'll need to find 128k chips that are 4 bit wide.
