Excellent!! Good job! Glad you got it functionalI bumped a couple of PowerBook RAM cards to max capacity, the first being a partially populated ‘death chime’ card suitable for a 165c/180c.
Well, I did my thing and found the bad chip, then put all the spare chips back on one bank at a time after testing them first.
Here’s the finished result, a lovely fully working 10MB card:
It has three buffer chips onboard which my other three 10MB cards not have. And interestingly, it’s the only one that fully works in a ‘fussy’ PB180 daughtercard that usually has stability problems when maxed out with RAM.
I also maxed out this (formerly 8MB) PowerBook 500 series RAM card to 32MB. It replaces another which was collateral during my quest to build a 48MB card.
Thanks to @imactheknife for the bits![]()
Great.. ship some to Newer so they can build that mythical G3 upgrade card for the 500 series!
Ya know, I had a sneaky suspicion that was why you were after a G3 card for a 1400. If that can happen that would be AMAZING.Hah. I'm hoping to reverse engineer a G3 upgrade for a PB1400 (when I get one) and do this myself.
so... you're looking for one?I'm hoping to reverse engineer a G3 upgrade for a PB1400 (when I get one)
I am, but it needs to be one of the ones with an FPGA onboard, which means Interware/Vimage. The Newer and Sonnet ones have a CPLD which is very likely copy protected.so... you're looking for one?
I have two Interware ones... I think one might have a borked FPGA tho... I'll try to have a look when I get some time.it needs to be one of the ones with an FPGA onboard, which means Interware/Vimage
Cool stuff.I have two Interware ones... I think one might have a borked FPGA tho... I'll try to have a look when I get some time.![]()
