Backporting HFS+ to Mac OS 8.0 and earlier
Well, I was able to boot System 7.5.5 from an HFS+ partition, but any other HFS+ partition could not be mounted. I also see no option to format partitions to HFS+, but only to "HFS Standard" or "DOS" (rather than the dual "HFS Standard" you guys were getting, maybe because a STR# or TEXT resource was forgotten).
For the record, even on Mac OS 8.1, at least ONE of my HFS+ partitions don't mount either (even though it mounts normally in 9.2.2 and OS X), but the rest do. What also happens is that Mac OS 8.1 (but not HFS+-enabled System 7.5.5) leaves my (HFS+-only?) partitions in such a state, at least when a crash occurred (but maybe also otherwise), in which the next time I boot an OS, be it 8.1, 9.2.2 or OS X, it takes FOREVER (20+ mins) for them all to mount, almost as if there was a minor HFS+-related corruption that needs to be auto-fixed by the booting OS (which seems to always work on OS X Tiger, and sometimes on Mac OS 9.2.2). No idea why. Perhaps 8.1 HFS+ is not as good, or not as up-to-date as HFS+ in Mac OS 9.2.2, or in OS X.
I mean, that wouldn't be surprising if true, even the likes of NTFS went through multiple versions and changes until a decade later with the Windows XP era or so, at which point it "stabilized".
It could also be that something isn't quite "perfect" about HFS+ in the 10.2.1 ROM for older systems, in the sense that what Mac OS 9.2.2 needs is all in there, but that the likes of 8.1, and earlier, are lacking that they need in the ROM file.
Again, I'm using my Mac mini G4 1.5 GHz model.
On a different note, for emphasis, this is exactly what I'm patching for 7.5.5 (everything taken from 8.1), in alphabetical and numerical order respectively:
boot, 3 (the one from DT 8.1 PPC should also work, perhaps it's even better? For Mac OS 7.6 and later, we use "boot, 2" from Mac OS 9.2.2 instead)
boot, 2246
gpch, 750 (for 68k Macs only)
gtbl, 6 (for 68k Macs only)
p2u#, 0
PACK, 2
ptch, -20217
ptch, 41
ptch, 42 (for 68k Macs only)
STR#, -20574
STR#, -20573
STR#, -20483
TEXT, -20574
TEXT', -20573
For @Rairii's 7.5.x/7.6.x Enabler, you must not touch "boot, 3" (dunno about "boot, 2"). However, patching everything else in the enabler also does not seem to work right, e.g. booting 7.5.5 from HFS+ won't work. However, if you patch ONLY "ptch, -20217" and "ptch, 41", as per @croissantking's instructions, it seems to work, at least to the extent I described earlier. I wonder what, exactly, we should and should not be patching in the enabler file.
That's it from my report for now. I'll try System 7.5.3 later (I don't think that one works at all, but I will see), and definitely try this (7.5.5) for running on Mini vMac in Mac OS 9.2.2. Note that if the latter works, it would bring HFS+ altogether to Mini vMac itself, since the highest OS version available in it is 7.5.5.
Just a little side note I didn't realize earlier about my previous comment:
- System 7.5.5 on 68k needs also boot 3 from DT 8.1 PPC, not any other boot 3;
- System 7.5.5 on PPC needs boot 3 from either Mac OS 8.1 or DT 8.1 PPC. For keeping the System HFS+ functionality "universal" across PPC and 68k, the one from DT 8.1 PPC should, then, be chosen.
I have yet to test all this on System 7.5.3 (native boot on PPC, Mini vMac on 68k on Mac OS 9 host). I have a feeling 7.5.3 won't work with HFS+ at all, but let's see.
Thank you. I have been trying to get this to work on 7.5.5 but always had a sad mac. Do you know how I can get the DT resources loaded in an emulator from the github page? I can import them fine but the resources are not available when using resminer or resedit.
Also, is boot, 2246 required for 6.5.5 68k?
Thanks
Thanks
I also wasn't able to figure out how to use the System resources hosted in the GitHub page, so I just used the actual respective System files directly under Mac OS 9.2.2, obtained from their respective install discs. In the case of DT 8.1 PPC, it should be contained within a disk image that is found within a retail disc of Mac OS 8.1.
What application is "resminer", by the way? I couldn't find any information on it.
And, yes, "boot, 2246" is required for HFS+ support in System 7.5.5 on 68k, as well as on any other pre-8.1 Mac OS both PPC and 68k, according to @elliotnunn's GitHub project.
I've been trying to work out what, in principle, would be needed to boot from an HFS+ volume on a 68k machine, which as we all know was never supported by Apple.
So far my simplest solution is to use (something like?) that old utility program from "back in the day" that let you boot from a small, limited disk and then transition to running from a different drive. I encountered it at university, where if I'm remembering correctly it was used to switch either from a floppy to a hard drive or from a very small hard drive to a Netboot volume. I wish I could remember what that utility program was called.
Now you've got my mind whirring; I encountered that at university too; the labs used it to boot from a basic boot floppy to a netboot volume. You'd pop in the disk, it'd do the boot and reboot, and eject the floppy which was then shoved into the next Mac in the line, to get them all to a network login screen. You're right; theoretically, this might be able to load the HFS+ driver and then load the secondary OS stored on the HFS+ volume.
It also reminds me of Apple's original HD20 loader that would boot an MFS floppy, then load the HFS drivers, and reboot to the HD20 drive. That was done with System 2.1 IIRC. The HFS driver stayed in RAM and wasn't present in ROM.
I did some digging, and the only thing I was able to find was an unsubstantiated assertion that "gbly" stood for "globally" and that resources AND file types with this string were loaded for global access (ie: any process can use them / be affected by them). Sounds reasonable, but I suspect this may be a backronym (the explanation came long after the type code).
I believe that "gbly" is short for "globally" about as much as I believe that "DSAT" stands for "Default System Alert Table".
Strangely, being Apple, I think there is official Apple documentation refering to them as "gibblies". Never assume something is logical 😆
Edit - see someone already shared this.
I just came across something that might be of importance.
Previously, we all mentioned a few times how important it is to have the "Text Encoding Converter" extension in order for HFS+ to function properly. That is also briefly mentioned in @elliotnunn's GitHub project page.
However, what I haven't seen anyone mentioning yet is this additional requirement according to Apple's documentation on HFS+ in the context of Mac OS 8.1 (and most likely all the way up to Mac OS 9.2.2):
Text Encoding Converter Extension and Text Encoding Folder
WARNING:
Proper installation of Mac OS 8.1 automatically places the Text Encoding Converter extension and the Text Encoding folder in the System Folder. In order for Mac OS Extended format to function properly, you must not move or delete these files.
... So not just the "Text Encoding Converter" extension, but ALSO the "Text Encoding" folder. I'm not sure I had that folder around when I did all my tests.
As for whether that will actually make a difference or not, I don't know. I have yet to check, perhaps on a weekend, if I get the time. But if anyone wants to check this on his or her System 7.5.5 ~ Mac OS 8.0 Macintoshes or even emulators, please do beat me to the punch and report back, I'd love to hear about it.
I might be wrong but I seem to recall part of the issue with booting HFS+ on 68k machines has to do with the scsi manager version in the ROM.
I’m not sure how how editing the rom for that would be.
Doesn't it just patch the ROM address with the driver on the disk partition when it spins up, before the filesystem load is even attempted?
i just had a look on Mac OS 8.1 and i suspect its probably only the 'Unicode Encodings' File that it needs from the folder
im not really to sure what that actual issue is because scsi manager is included in most/all? 040 68k mac roms but they still cant boot hfs+ drives. its jsut something smarter people then me have told me for year and years.
to me i would suspect that the ROM needs to have a hfs+ driver in it that gets called during initialization.
early 64k macs needed to boot up with the hd20 init that would load the hfs driver into ram and then reboot to the hfs drive, then the 128k roms added hfs into the rom itself to allow direct booting. it might be a good place to start.
i dont know it's possible but then a patch could possibly be loaded from the 'Apple_patch" partition to allow hfs+ to boot on 68k? failijng that a modified rom is likely needed
