BlueSCSI Laptop to external WiFi Antenna?
Trash80toHP_Mini
NIGHT STALKER
68040
Wondering if a hookup or workaround for running an external antenna lead outside the RFI shielding of a Mac is a possibility?
Running the lead to a wire type antenna in a PowerBook lid might be ideal? RFI shielding of a Duo's HDD bay can be tucked underneath, but dunno about other 'Books Also thinking of mounting the BlueSCSI Laptop version on a dummy card in the CSII slot of my 6360. Should be workable for older CS slot of my Q630 as well.
Could custom CS/CSII carrier board provide power to BlueSCSI?
from what I understand... there is no place to connect an antenna to the pico.
otherwise.. it would be a great idea :)
outside the scope of the thread I think ;) you could... but why would you? lots of pain for little gain. just use an SD extender if you need to expose the slot.
Dang! might a larger than Pico version with antenna hookup be suitable as the CPU?
Running a power lead to a CS/CSII unit would be a PITA.
However doing a CS/CSII specific version with MicroSD slot and antenna lead available on the backplane of 6xxx/5xxx would be killer!
Found an off the shelf solution:
It's massive overkill to treat the SCSI to SD conversion as a HAT on a full blown Linux Computer, but the added CPU cost isn't prohibitive.
Now thinking in terms of an LC NIC format SD/WiFi solution. Far more PCB real estate and cubic available than CS/CSII format and the SCSI connector is right there!
pi zero and pico are two different things
Indeed, that's why I said it was massive overkill as a replacement for Pico.
Just watched the vid I linked above that relates directly to Pico.
Seems like an easy enough mod that's better/more flexible by installing a cut cable's leads directly to board contacts leading to the antenna connector on the other end rather than installing a connector on the Pico to plug in the full intermediary cable?
Would you be able to (practically) connect a BlueSCSI internally to a Performa 630/5xx0/6xx0 style machine, with their IDE hard drive?
Optical drive on those is SCSI, right? you could replace that with a bluescsi
Or, might be able to replace the internal SCSI ribbon cable with a dual connector one and put a bluescsi internally there somewhere, but might be a pain
db25 bluescsi might be the best bet for that if you wanted to keep the optical drive
IDC 50M connector crimped onto the SCSI section of the harness underneath the CD adapter bar would be my suggestion.
Unless you listen to radio with the tuner box, that cubic might be about perfect for a laptop SD solution? Out of town ATM, so I can't check for fit.
Thinking 2.5" might be too wide. But if the cubic is available, it might be possible to print a slide out drawer with co-ax connector for antenna and USB-C(?) programming. That would provide the required cubic without deleting either the CD or 3.5" IDE drive or CF adapter in that bay..
Ideally, a longer/narrower version of an SD solution would allow it to fit on a Dummy CS/CSII card or a dummy LC NIC opening up a reasonable market segment for such a contraption?
edit: just found the ZuluSCSI pico slim which could fill the bill. Not a fan of hanging such a device off the SCSI port externally. But doing a 50-25 pin conversion of internal cable by soldering the 25 wires to the board would do nicely. Should work on either LC NIC or CS/CSII dummy cards.
;) Front bezel pops off easily enough for card changes. WiFi antenna lead and USB-C cable can be routed to Tuner Bay cover or the vestigial LC port cover. SD extension cable as well?
