Generic Block Game - Happy #MARCHintosh 2026
DW1992
Hi Everyone,
Well, I wanted to build the top down re imagining of the Atari game COMBAT : Tank Pong for #MARCHintosh, but very quickly learned that to do it properly, I need a lot more time... and a lot more knowledge. 🤪 So I haven't given up on it, it's just been delayed.
In the mean time, I decided to write a little clone of Tetir... err.. I mean.. a totally original and unique Generic Block Game... :geek:
I targeted the 68040, and tested with my L475 and CC MYSTIC (LC575) running Systems 7.5.5.
Also runs great in Basilisk II.
I'm working to optimize it a bit further for even more particle fun.
Some of the effects you may recognize from PewPew, šŸ‘¾šŸ‘½šŸ›ø like particle explosions and screen shake. 🄳
šŸŽµ Contains 5 music tracks, selectable by pressing 1-2-3-4-5 and 0 to mute (why mute?!?). šŸŽ¶
DOWNLOAD the .SIT HERE
Happy #MARCHintosh 2026!
Questions, comments, suggestions, bugs, anything please shout!
Aaron/DW
Dark Systems BBS
I will have to download this to see how it compares to some other non-generic block games which I have run on my vintage macs! Good work :)
Cheers :)
It was a lot of fun to try and write in a short turn around, and I learned a ton doing it. Now, if only I could remember it... :p
As always, the fully commented C source is available, as well as the full CodeWarrior PRO 4 project folder, including all resources and libraries.
Grab the .SIT containing the source, resources, libraries & CW project HERE
If you just want the commented source code text, download the main.c.txt file below and remove the .txt extension.
Enjoy!
Sorry for the state of my code... and the comments.. my sense of humour is very 80s. šŸ“¼ It was a wild time... šŸ˜‹
If you make improvements or other features, share them up!
I'd love to see and learn from them!
Aaron/DW
Dark Systems BBS
It looks pretty good, and I'm glad that there are still people willing to develop software for the 68K Mac.šŸ˜
Thanks. :)
It's a fun platform to develop on while trying to remember the tricks from +35 years ago. lol
There's something relaxing and satisfying about it when it (finally) works and compiles as it should. :ROFLMAO:
I have a little pseudo-3d racer in the works, before returning to my Tank Pong clone. See if it's still relaxing when that's done... lol šŸ˜‹
Little preview.. :)
Struggling with masking the 8bit colour sprite in a gWorld setup.
Not as simple as the 1bit CopyBits / srcOr operations used in PewPew. :alien:šŸ›ø
Damn you 1994 lack of Alpha channel! šŸ˜‹
Slowly improving (learning.. very slowly. lol)
Once it's to a playable / presentable state, I'll start a new thread for testing.
Cheers!
Aaron/DW
Dark Systems BBS
P.S.
The placeholder Jeep sprite is inspired by my daughter & my actual adventure Jeep. šŸ˜‹šŸ•ļø
Finally got it working! 🄳
Needs some (a lot) cleanup, and my palette seems to have gone a little wonky (mountain sunset?) šŸŒž , but it's cookie cutting my 8bit Jeep out now. :)
A little particle effect on the tires happening now as well (stolen from Pew Pew of course). :)
Basic gist of it...
Code:
    /* CAR RENDER (MASKED) - void DrawRaceFrame */
        short carW = 160;
        short carH = 170;
        short carX = (G_WIDTH / 2) - (carW / 2) + (gPlayerX >> 3);
        short carY = G_HEIGHT - 170 - 10;
        SetRect(&carRect, carX, carY, carX + carW, carY + carH);
        GetGWorld(&oldPort, &oldDevice);
        SetGWorld(gOffscreenGWorld, NULL);
        CopyMask(
            (BitMap*)*GetGWorldPixMap(gCarGW),
            (BitMap*)*GetGWorldPixMap(gCarMaskGW),
            (BitMap*)*GetGWorldPixMap(gOffscreenGWorld),
            &(**gCarPic).picFrame,
            &carRect
        SetGWorld(oldPort, oldDevice);
I'll write out a proper detailed version in the source when it's all cleaned up and working well.
Aaron/DW
Dark Systems BBS
To be honest, I’ve become completely reliant on the syntax highlighting and autocomplete features of modern editors. I’ve been working on a Mac II emulator, and when I try to program on it, I feel like I don’t know how to do anything.
"when I try to program on it, I feel like I don’t know how to do anything." then you'll fit right in with me! šŸ˜‚
To be fair, I've been reading through jonathanopalise's PPENGINE, a 3D Linux clone of PolePosition, to get some hints on the logic math and techniques, then building it in a 2.5D style using GWorlds, QuickDraw and friends. šŸ˜‹
CW4is limited by modern IDE standards, but it's pretty slick for the era.
You can even customize some syntax highlighting beyond the included defaults.
To be honest, I am an outsider in this area. Could you please tell me how to compile this? Thanks
No worries, do you mean compile Generic Block Game from source?
You can grab CodeWarrior 4 PRO here
Download ResEdit here
Grab the .SIT file containing the source, libraries, resource and CW project here
Once CodeWarrior and ResEdit are installed, extract GBG_Source.SIT and open the resulting folder. In here you will find the CW project itself.
Double click the blockgame project file (little grey symbol on it).
Inside CodeWarrior, you should see a listing of all the files, etc... that make up the game in a window.
Double click on the resource tetris.rsrc will open it with ResEdit.
Here you can change the available music, icons, high score, menus, etc..
If you double click on main.c this is the actual source for the game.
It's all commented, so play around! You can always restore the original version from the .SIT you downloaded.
Change block shapes, speed, particle effects, anything!
To run the code, simply select PROJECT from the top menu and go down to RUN (cmd + R).
I'm curious to see what you come up with.
Let me know!
The source / project for Operation : Pew Pew is also available on my Demozoo profile if you want to play with that too. šŸ›øšŸ‘½šŸ‘¾
It's the exact same process for editing and compiling.
Aaron/DW
Dark Systems BBS
Oh, thank you. So that’s why I couldn’t find the project file icons—I inserted my CW4 disk after the project had already been extracted, so all the files appeared as ā€œdocumentā€ types.
The graphics and music in this game are greatšŸ˜, but it runs a bit slowly.
Cheers for the kind words. I'm glad you like it!
Ya, I'm still learning how to properly optimize for 68K.
Meeting limited success... :geek: but it'll come! šŸ˜‹
It's the particles that slow down Generic Block Game (and the mixing of the MOD background music).
Disable them, or drop the particle count to nearly nill and then run. It'll be zippy. :)
I was wondering if it’s possible to use VBLTask instead of putting everything in an infinite loop. I remember reading in "Inside Macintosh" that there’s something called asynchronous audio.
Cheers, and thanks fro the suggestion!
I wonder if I can change my TickCount() to use VBL, replacing if (TickCount() > gLastMoveTime + currentDelay) with VBL timing and get 30fps from the ~60Hz sync... lemme thing (queue smoke) :unsure:🤪
Might get smoother, more consistent movement of the pieces.
The sound effects / voice sample use asynchronous audio now (else the code would stop until the sample finished playing). šŸŽ·šŸ” But I do think I could further optimize the music, or at least give the player the option to change sampling rate, or select between mono / stereo.
I'll return to GBG asap. Work has taken over unfortunately (got assigned 4 new recruits... I should get them to beta test this! 😜 ) and my 2.5D racing experiment game is always on my mind. lol
Thanks again!
Aaron/DW
Dark Systems BBS
A little update on the 2.5D racing engine...
It's at the point where I think it's ready to have people play with it and help make it better, so instead of continuing to post about it here in the Generic Block Game thread, I created a new post just for it.
You can find it HERE :)
UPDATE v1.5
I learned a lot about optimization while writing my Dark Systems BBStro, and have tried to implement some of those tricks here, with Tetris, err... I mean, Generic Block Game. 😜
The biggest fix would be the Gestalt based CPU detection function.
Based on the returned value, the ticks, or Frames Per Second, are adjusted (up or down).
The player (you) can also manually adjust the FPS under the new 'THROTTLE' menu.
The original game was hard coded to try and maintain (force) 60fps.
The background music will also be enabled or disabled based on the detected CPU.
Pressing 1 through 4 will still force the various tunas to be played, with 0 being mute.
Download the latest version from my Demozoo profile.
As always, suggestions and requests always welcome!
DW/Dark Systems BBS
