IIsiA7 Mini: HDMI for the 68030 PDS slot (bis)
Hello all,
At last, the IIsiFPGA's smaller sibling is here: the IIsiA7 Mini. It's basically the same thing (the Highly Desirable Macintosh Interface for the IIsi), but smaller, so it shares a GitHub repo with the original version (and refers to itself as the IisiFPGA V3.0).
So, what's new? Well this time, there is no daughterboard - the FPGA is actually soldered directly on the board (and trying this was the reason for me doing the board in the first place). So
  • It's smaller: it fits in the form factor of the IIsi adapter (but the HDMI connector isn't usable with my cables, too close to the case, so you still nee the adapter...), and it doen't have the massive thickness of the *FPGA
  • It's cheaper: well, technically it is more expensive (it's a 6 layers PCB with a 256-balls Artix-7 so it ain't cheap to make even at JLCPCB), but as you don't need the FPGA daughterboard, the overall cost of the solution is (much, much) lower - less than 2/3 of the ZTex 2.12b alone!
  • Requires a JTAG programmer (no onboard USB programmer, which would have raised the BoM significantly)
  • Also it uses a DDR2 chip instead of DDR3, which means lower memory bandwidth but it seems ok for 1920x1080@32 bits anyway.
Here's a picture of the board:
It supports the same set of options as the larger siblings in the family, with the choice of two HDMI PHY: either DVI-like with support for multiple hardware resolution (640x480 to 1920x1080 at 1/2/4/8/16/32 bpp) and windowboxing (but no audio), or closer to the better-known HDMI, 1920x1080 hardware resolution only (at 1/2/4/8/16/32 bpp) with windowboxing and audio. There's also a PMOD connector and a serial-to-usb connector for tinkering with the gateware.
Annoyingly, I have a bug in the gateware than mistify me; the burst read from memory doesn't work despite the code working fine on the original IIsiFPGA (the new version requires an additional width converter, as the IIsiFPGA's DDR3 1:4 ratio exposes a 128-bits wide interface perfect for a '030 burst, but the DDR2 1:2 ratio exposed only a 64-bits wide interface, and that converter works fine for the acceleration engine...). Memory expansion mode works without it, but it's slower than it should be. Grr.
The original batch of IIsiA7 Mini has a slightly larger Artix-7 than the ZTex I used with the IIsiFPGA, as the 50T was cheap at time of ordering at JLCPCB - so I got that one (vs. a 35T). It's actually big enough to fit both the SQRT and DIV operator at the same time when adding my ongoing FPU project (so it has all the '040-supported FP compute instructions at in 80-bits Moto, 64-bits IEEE and 32-bits IEEE).
All the files are on the repo, as usual.
Nice, as usual!
For the HDMI connector, you can find HDMI female to FPC breakout boards and shielded FPCs on aliexpress - that could provide an easy option for a remote connector. Or roll your own.
Do you run into any drive issues with the FPGA -> FET arrangement? As I understand it those only provide voltage translation but drive strength remains the same as the original FPGA pins.
I just use the board with a (homemade) riser with two PDS slot, so I can also have my (homemade) version of the SEthernet/30 and get Ethernet. For now I haven't bothered to make things pretty by having a proper backplate, I just run the cable to the inside of the machine... a bit 'yuck' but it works well enough.
Angled HDMI cable (90°) appears to exist, but I don't have one to check if that would fit.
Speaking of form factor, I forgot to mention: the IIsiA7 Mini should fit in the SE/30 as well, and should also work in the IIfx with an appropriate bitstream (but I own neither machine to try).
No, for now I haven't seen reliability issue with any of the designs (SBus @ 25 MHz, NuBus, '030 PDS, '040 PDS). I think the 7-series default to 24mA drive, and that appear to be enough to reach 'high' level (>2.4V for 5V TTL) quickly enough.
But the test conditions are usually favorable; I didn't try in a loaded 6-slots NuBus machine or in a SE/30 with stacked devices.
I have two IIfxen, if that was a solicitation for testing help...and no, I'm not expecting free hardware.
Not yet, still need to sort out the burst read issue and do more testing.
Also I'm in Europe, and shipping to the U.S. has been too complex for a while, should I sell my surplus board it will be more locally (shipping internally in the E.U), sorry. Source and production files are on GitHub if someone wants to run their own batch. BTW, the license is CC BY-NC-SA 4.0, but I'm fine with someone selling the surplus boards if they made some for themselves. I'll put a reference bitsteam on GitHub when I'm happy with the status.
Did you solder U1 and IC1 yourself or can you let the guys at JLC do that?
Everything but the DIN connector was done at JLCPCB (there's a LOT of 0402 capacitors on the backside, plus the oscillators and the flash for the FPGA). The DIN I soldered myself because I can do it and through-hole is expensive at JLCPCB (and they didn't have the connector in stock).
Spectacular work! FWIW just in case I can be of any help with testing/iteration, I have a JTAG programmer and an SE/30 with a few stackable PDS cards in hand (zzj Booster 2.1) or on their way this week (Bolle combo ethernet+cache slot adapter & Turbo 040 repro - super excited about this one!) and am in the EU (Netherlands).
I don't blame you; it has become quite a mess. However, I'll be in Spain for a couple weeks in April/May and in my native Norway for several weeks in May and June, so the logistics I could potentially work around. But Jockelill just made me an offer as well.
That said, if the hardware from Jockelill is in any way useful for testing on IIfxen, I'd be happy to help. I suspect it won't be since the integrated design is different, but still.
