Dove MacSnap 5.0 RAM Upgrade Upgrade
mitchW
I am restoring a Mac 512K with a 512K Dove MacSnap 5.0 RAM Upgrade card + SCSI.
This upgrade card brings the Mac RAM to 1MB.
But I've seen some other Dove MacSnap RAM Upgrade cards that contain 1MB or 2MB of RAM.
Is it possible to upgrade my upgrade card to 1MB or even 2MB?
Also, one of the snap connectors is bit corroded, any possibility of getting a new one? Or were those made to order parts just for this upgrade cards?
you can fix the corrosion by using white vinegar
Thanks, I did use a special "gentle" rust remover cleaning product that I usually use for corroded stuff and it turned all green corrosion into dull grey metal. I will try white vinegar if it will make it any better
Can you post pics of the card? It might be an easy upgrade to 2MB. Great cards these, really make a 128/512K useful.
Here, I snapped few pics of the card :)
The card looks in great shape!
To upgrade it, you just need to populate the missing 32 ICs with 41256 DRAMs (256K x 1-bit) and add that second 74253 multiplexer chip on top. You should also check if the two 150-ohm resistors are present; if not, you'll need to install those as well—along with those 0.1 µF yellow capacitors.
Regarding the logic chip, it doesn’t strictly have to be a 74F253; a 74HCT253 or 74LS253 will work just as well in this application. Once upgraded, the card will provide 1.5MB, which, combined with the 512K on your motherboard, gives you a total of 2MB.
The hardest part will be sourcing 32 matching 41256 chips, as they are becoming harder to find in large batches. As for the corroded snap connector, those were, unfortunately, proprietary to Dove.
Thanks!
I checked my parts bin, and I actually have 18 of 41256 ICs (not tested though) and a 74F253! Other missing parts, I can order :)
But now I found some photos of the fully populated Dove MacSnap 5.0 on ebay, but it seems it has and additional snap connector for one chip on top of the card (for connecting onto LS04 chip, I guess). And if they were proprietary, then even fully populating won't work.
I did find some photos on of that same board, but with 16+16 memory ICs (two thirds populated, so 1024K). Perhaps this configuration would work without connecting to LS04 chip? I am not sure though. Even having 1.5MB of RAM is better than 1MB though.
Actually, the model of your MacSnap board isn't '5.0', that's just the PCB revision.
Your board is a model '548.' Apparently, it seems the model names with an "E" at the end were specifically for the Macintosh 512Ke. Those 'E' versions have an extra snap-in socket connector for LS04 to tap address bit A20, which is used by an additional logic chip (74F259).
I've reverse-engineered the logic of this board; pin 11 of that 74259 connects to pin 15 of the additional 74F253 found on the fully populated 1.5 MB models.
It looks like what it does is disable writes to a specific memory address region: link
From a functional standpoint, it doesn't affect the normal operation of the machine. We never quite figured out what it might be needed for.
So, you don’t actually need that additional snap-in socket connector and the 74259 to get 1.5MB (Just tie pin 15 to GND). But if you want to implement the 74259 anyway, you could just tap A20 from the logic board with a bodge wire.
This is great information. I have a couple of MacSnap RAM expansion boards that were installed in two Mac 512k's. One had just the bottom portion of the board filled (512k RAM) and the other was fully populated with a MacSnap SCSI board.
I populated the board with similar RAM chips and I was curious as to why I did not get the full 1.5mb upgrade. This answers my question. So I can place a jumper on pin 15 where the 74259 chip is located and run it to a ground. Correct?
The fully populated board had a jumper from the SCSI board to the RAM expansion board. Would you know what the reason why it was placed?
Thank you in advance.
For the 1.5MB configuration, you need to have the second 74253 populated, as shown in your pictures of the 1.5MB boards. In both models (512KB and 1.5MB), pin 11 of the missing 74259 is already tied to ground (pin 8). That blue component is a 0-ohm resistor.
This is actually really interesting! It’s the first time I’ve seen a connection like this.
It looks like it’s injecting the LDS signal directly from the TSM PAL (Pin 9) into the SCSI board at J1, pin 2. I’m not 100% sure on the exact logic yet, but if I had to guess, it’s probably a failsafe to tighten up the data latching for the SCSI chip.
If LDS isn’t asserted perfectly during a SCSI access, the controller won’t "see" the data on the lower 8 bits of the bus, which usually leads to those annoying bus corruption issues.
In the original Mac design, these strobes are timed against the 7.83 MHz clock to make sure the data is stable before a peripheral tries to grab it. So, the equations in that DOV1 GAL are likely using this strobe to give the SCSI IC a much cleaner latching window.
Checking the equations stored in the DOV1 should corroborate that.
Okay, it seems I was right!
In the Macintosh Plus, the SCSI IC has its /IOW and /IOR connected to /LDS and /UDS, respectively.
The SCSI MacSnap logic generates its /IOW signal (pin 15) at DOV1 like this:
/o15=i8 & /i9 & o19+i8 & i11 & o19
o15.oe=vcc
The first term never gets activated since i9 is simply being pulled up by R3 if nothing is connected to pin 2 of J1.
Consequently, /IOW is always directly generated by the second term, which is gated by the RC circuit formed by R4 and C4 (i8).
I haven't found an installation manual for the DOVE SCSI MacSnap, but looking at pictures online of people who have this board installed in their 512Ks, I have never seen this bodge connection before.
I suspect the DOVE engineers primary intention was for the SCSI board to work perfectly without this bodge. It is likely that J1 and the first term of o15 are there for factory verification, to ensure the RC time constant from R4 and C4 stays within the timing window for latching data from the SCSI.
Whoever made this connection clearly understood this; it is more than probable that the R4 and C4 values are not providing the correct RC time constant for the SCSI interface to work reliably on your specific board.
The other signal including i9 is for /IOR (pin 13), as expected:
/o13=i8 & i9 & /i11 & o19
o13.oe=vcc
Here, i9 directly gates /IOR. With the bodge in place, whenever /LDS is asserted, /UDS is unasserted , as expected.
Demik is the right person to test whether this bodge connection improves the reliability of the MacSnap SCSI replica!Screenshot 2026-03-13 at 9.47.25 AM.png
It is no wonder the original and replica MacSnap SCSI boards are so finicky.
The RC time constant from R4 and C4 is clearly designed to mimic a full CPU access cycle, which always takes 4 clock cycles on these early Macs. The problem is that any shift in that timing, whether from aging components, voltage drops on a tired analog board, or extra capacitance from crusty pin headers, will easily push that constant out of spec. Once that happens, your SCSI data integrity goes right out the window.
The primary goal for DOVE designers was creating a product that a regular user could simply press into a socket without having to fire up a soldering iron. It was a brilliant marketing and usability decision for a product that was only expected to be relevant for a few years.
This board remains the absolute best way to open up a closed system like the 512K to the modern storage world. Getting a SCSI emulator running on a 512K completely transforms the machine from a neat display piece into a highly usable system, especially when paired with a fully working 4MB RAM expansion board.
It really looks like adding that bodge wire is almost mandatory if you are having SCSI issues on a Mac 128K or 512K. It is the only way to swap over to solid, CPU-synced timing. Fortunately, the PLD logic is already tailored to use the /LDS signal. All you need to do is tap /LDS from the motherboard and connect it to pin 2 of J1.
Since J1 was removed from the replica board made by Demik, the owner of a replica board will instead need to connect the bodge wire to the junction of R3 and pin i9 of the DOV1ß PLD. It should work, though it will definitely need to be tested first.
All of this is thanks to pezter22, who published that ultra-rare photo of this SCSI board showing the bodge wire!
I just finished building two of Demik's MacSnap SCSI boards today. I'm hoping to install them in my Mac 512k's with that have the MacSnap RAM expansion boards.
I think I saw why one of my boards was not providing the 1.5mb. I just saw that I did not place a resistor at R53 near the 74F253 IC. Do you know the value off hand?
I am building a CatMac board with a MacSnap RAM expansion board and was hoping to use the recreation MacSnap SCSI board, but it's a bit too large to use both. The original two MacSnap boards were already a tight fit. I guess I am going to have to choose one or the other for my Mac 512k's. Luckily I have my original that I can stick back in soon. I'm going to install a BlueSCSI 25pin external inside the Mac 512k.
These are great boards and Demik's recreation is fantastic.
I think there might be a simpler way to look at this. The MacSnap RAM boards you have use the same PCB layout and connections; the only real difference is that one was fully populated for 1.5MB, while the other was originally populated for only 512KB.
The resistor looks like it is 47 ohms, but check it with a meter just to be sure. Also, you will need to populate the jumper that is next to RP6.
One more thing: since you are using a BlueSCSI 25-pin board, you don't need to populate the X, Y, and Z resistor packs if you are using the original MacSnap SCSI board. The BlueSCSI already includes the necessary termination resistors.
Thanks for the much needed info. That would explain why when I opened up the Mac 512k, I saw that a previous owner had clipped off the resistor packs. I added them back on, but will remove them as I get closer to getting it back together.
Right now I just have the original RAM expansion board in it. When I took the SCSI board off I broke two ROM header pins on the card and had to solder on new pins.
I recently purchased another Dove MacSnap RAM expansion board and will be adding more memory to it soon. That's the one I was hoping to use the recreation SCSI board in the CatMac. I love the Mac 512k.
There is one more thing to be aware of when upgrading the MacSnap model 524 board to the 548 (1.5 MB) model.
Looking at the pictures of the backside of the 512 KB model uploaded by mitchW in this thread, it seems that his 512 KB model (524) did not come with the snap-in socket on the backside for the H4 socket.
If your 524 model is also missing this socket, you will need to tap the A20 address bit from the motherboard (pin 5 of the LS04 IC) using a bodge wire and connect it to pad number 5 on the H4 socket footprint.
The A20 address bit is used by the second 74253 to select RAM above 1MB; the sole purpose of the H4 socket is to tap that signal and nothing else.
You could also solder a machine header strip to the right side of the LS04 IC and use socket pin headers for the right side of the H4 socket footprint. While this requires a high degree of craftsmanship to execute correctly, it would spare you from having bodge wires running across the motherboard.
In a previous post in this thread, I mentioned that A20 was only used for the 74259 IC, but that was incorrect. I have since checked my reverse-engineered schematics for this board and confirmed that A20 is indeed also needed for the second 74253. Sorry for the confusion!
To summarize: In order to upgrade the board to 1.5 MB, besides populating all the missing 256 Kb RAM ICs, you also need to:
Add the second 74253 IC.
Add the R53 resistor.
Add the jumper next to RP6.
Tap A20 from the motherboard (pin 5 of the LS04) and connect it to pad 5 of the H4 socket, in the event that the socket is missing.
Thanks for the additional information. Those piggyback sockets are unobtainable. I was going to solder some machine headers to the LS04, but it's definitely difficult to line them up correctly. I think it would work better for me to run a jumper from the motherboard to the expansion board.
I appreciate the help. Thanks.
Builder68 thanks so much for all your help. I was able to get 2mb of RAM installed with the MacSnap RAM expansion board.
This is great.
I also installed the MacSnap SCSI adapter. I added a 50 pin connector to it. I made sure to match up pin 1 with the card and the connector. However I am not getting power to the drive (BlueSCSI). I originally attached the 25 pin SCSI to a external BlueSCSI but received no power to it. So I attached a BlueSCSI to the 50 pin and powered it with the Pico power supply using a 4 pin Molex to a Berg connector. I am still not receiving power to the BlueSCSI.
I'll keep trying, but I'm just happy to get the full 2mb of RAM.
This is great.
That is great news about the 2MB of RAM!
Regarding the SCSI issue, there is a specific reason you aren't seeing power: unlike Demik’s MacSnap SCSI PCB replica, the original MacSnap SCSI board does not provide termination power (TMPWR) to the SCSI connectors.
If you want to power your BlueSCSI directly through the SCSI bus, you can modify the board by adding an 1N5817 Schottky diode and a 10µF polarized capacitor.
The cathode (the end with the stripe/arrow) must aim toward the IDC footprints, connecting that end to Pin 24 of the IDC-26 footprint and Pin 26 of the IDC-50 footprint (double check IDC-50 pinout for SCSI cable!).
Connect the anode (the other end of the diode) to a nearby VCC source, such as Pin 25 of the 53C80 SCSI chip.
Place the 10uF cap between TMPWR and GND.
Please perform these modifications at your own risk. I highly recommend double-checking the pinout diagrams for the IDC50 SCSI connector first to ensure none of those pins are inadvertently tied to ground before you apply power.
Screenshot 2026-03-21 at 1.31.05 PM.pngScreenshot 2026-03-21 at 1.42.30 PM.png
I finally got power to the BlueSCSI 50 pin. I rechecked my connection from the Pico power supply and did not have the connector in all the way. On reboot I did get a power LED on the BlueSCSI, however the activity LED came on for only 5 seconds then shut off.
I rebooted with my FloppyEMU booting into System 7 Disk Tools it did not see my BlueSCSI.
Earlier you mentioned removing the three resistor packs used for terminating. Could this be an issue?
Either way, I am happy I was able to get the added RAM.
