Performa 630 CD-disk drive died ?
Hi everyone,
i recently got into old macs (go figure), i got a performa 630 which was described as working, it did work when i got it but the PSU only powered on in a minute after leaving it plugged in and had a heavy coil whining sound. I recapped the PSU and Mobo since i didn't want to test it for long with that whining ass PSU. It worked great after recapping, for about 5 minutes then something sounded like someone got shot and it triggered my circuit breaker, something shorted out in the psu (dunno what), i then decided to mod a modern SFX PSU in there someone described on here in a lovely thread (thanks again for that very cool!). The System works great now but im still having issues.
I tried installing System 7.5.3 it would boot fine off of my burned CD-R, and installed fine, but i got an error after trying to boot from the IDE drive, 0000000f 00007fff, weird, i tried installing System 7.5.3 again, but it crashed at 2/3 of the installation. Now i can't get it to boot from the CD drive anymore, it spins up and starts reading (doesn't consistently start reading on power up just sometimes), the happy mac does appear but after a minute of him being there he goes away and it returns to the ? floppy. I suspect the drive died while Installing, i ordered a used one from ebay already and i'm gonna try that, but in the meantime i wanted to ask if these drives have some common failure points? I dissasembled the drive cleaned the laser and looked at the cables and caps and everything looks like it's in order. Are failures on these common? I feel like it might be a easy fix if i knew how, after all it was working before.... I also tried freshly made boot disks of 7.6 but those also fail after the happy mac...
The symptoms you're describing are textbook indicators of a failing laser assembly.
Early CD-ROM drives used Laser Diodes that have a finite operational lifespan. The light output physically degrades, and the beam becomes too weak for the photodiode array to "see" the reflections from the disc clearly.
I've had a few of them where the caps are leaking, required re-lubing, or plastic parts inside had broken.
Is this a lifespan measured in use-hours (I assume) or is it a matter of them degrading over time regardless of use? If it is hours, any idea how many?
I'm fairly certain it is use hours.
Damn that sucks so its basically unrepairable. But i received the other cd drive that one works great, but the crash corrupted my harddrive its not being recognised anymore. Got a CF to Ide maybe that'll work.
Well, you could replace the laser diode, but unless you could calibrate it, there would be no point since they need to be calibrated to ensure they can focus the laser correctly.
I got really good many years ago calibrating replacement laser assemblies in SEGA CD/Turbo CD/etc game consoles.
It’s not as daunting or hard as you think; nothing like trying to calibrate a zero track on a floppy drive.
I say all that to say—it’s doable. I had zero experience in the beginning, only sheer determination. 😀
Thanks guys, maybe once i'll get an oscilloscope i'll fiddle around with it, for now im just gonna put it away.
I just have on more quick question and don't want to make another thread. How do i initialize the CF Card? The original utility fails at the initalization stage no matter which version i use of drive setup. I do not have access to another mac to get another software like Formatter five to run, is there some formatter software i can use via a 1.44 floppy to initalize the card or is there some other way? It's being recognized fine by the system and showing 977MB free.
I already have a Industrial CF card, the issue was just that the drive tool can't get drivers installed (even the patched one) it simply doesn't Work with a CF card. But the User Bolle sent me a floppy with Formatter Five on it, used that and now everythings working fine got System 7.6.1 installed Just fine. Thanks again Bolle Very Cool!
Sure here is the PSU i used, fits perfectly i cut out an adapter mount from an old Amiga 500 external floppy drive casing.
https://www.amazon.de/APSIII500-Net...22610&sprefix=tacens+anima+sfx,aps,114&sr=8-3
and here is the thread on the forum:
