Do any current low-end laser printers play well (or poorly) with older (post-Classic) OS X macs?
My 20th-century HP LW just went out in a way with no quick-fix this time, and a backup (inkjet) pulled from longtime-storage was DOA.
So looking to quickly get one of the apparently many sub-$200 (even sub-$150) monochrome laser printers with physical ethernet port, until have the time to try repair. Brands include Brother, Canon, HP, Lexmark, Xerox, etc.
Low-volume printing of clear sharp text is the major requirement. Seems most are listed as 1200x1200, a 700 page cartridge, WiFi(AirPrint?) and besides GDI, some sort of PS and/or PCL emulator(s). Pretty sure they'd all print with Mac OS 11-26. Realistically will never need to print directly from a Classic OS machine, but network-print from OS 10.4+ would be great.
Wondering if experience here indicated any printers in particular need to be avoided if ever want to print from an older mac, or if any happen to be great printers for the price.
(Avoiding manufacturer firmware "locks" to highly (rather than just moderately) overpriced toner would be nice too, if the machine stays in use.)
Thanks.
I don't know about current but I picked up an Oki 321dn before the pandemic and I can print from my Mac OS 9 macs on it.
I haven't tried my G5 on it yet but I see no reason why it wouldn't work.
It is a colour 600dpi printer and prints A4 (and, I suppose US-Letter).
The latest USB-only Brother laser printer has built-in compatibility modes for PS and PCL, as well as specific HP profiles AND a CUPS-compliant default driver.
That said, I haven't actually tried one from 10.4 yet; I've got the wireless version myself, which is slightly different, and the people I know who've got the USB one don't run legacy OSes.
These days, I'd avoid all modern HP printers (and all modern Epson printers too, and some modern Brother printers, and some modern Lexmark printers). So that pretty much leaves select Brother printers and most Oki printers.
Possible contenders to investigate:
Brother HL-L2350DW
Lexmark MB2236adw
Oki C332
Xerox Phaser 3260
My 20th-century HP LW just went out in a way <snip> Pretty sure they'd all print with Mac OS 11-26. Realistically will never need to print directly from a Classic OS machine, but network-print from OS 10.4+ would be great.
Thanks.
We have a Canon MF641C Laser Printer, which prints wirelessly from our MacBook Airs (M2 and Intel 2019) and Mac mini 2012. Haven't tried it with my MacBook C2D 2008, but I can try it. There's a driver that goes back to Mac OS X 10.5, so it should work (with my MBc2d.. and it might also work with my Mini G4 as it's running 10.5 too) I guess.
Sometimes it stops talking to our Macs, and we have to re-add it. Other than that, it's been great!
Most printers will work. Until recently, I had a LaserJet P1006 that I used under 10.6.8 through 10.13.6. Worked fine. Stopped using it because we have an OfficeJet that has wi-fi built-in, so no need for a print server.
Also have used various Epson printers without issues.
Appreciate the comments. They've helped.
Some of the models you listed were on my radar already. And...
- Wow. Wasn't aware Okidata ever continued beyond dot matrix. Looks like they exited the US printer market a few years ago.
- Xerox purchased Lexmark last year, and it seems the Xerox lower-end printers are re-branded Lexmarks. Wonder how that is going to shake out for future branding and driver support.
- Definitely surprised at the relatively low prices for color laser printers like the Canon multi-functions mentioned.
Most web-search results link to that near-monopoly multi-forum "r/" website, where many posters appear to be anti-HP, pro-Brother evangelists.
The old HP Laserwriter is now looking non-repairable, and may have to retire it. (PostSctipt/PCL, JetDirect EIO RJ-45 + Parallel port + LocalTalk !!! ports, which worked at least down to the lowest OS here (7.6)). So may just have to at least consider a permanent mid-level printer, rather than a temporary lowest-end model.
What model is your old printer? HP's old LaserJets are pretty serviceable. Many are impossible to kill, only being EOLed by lack of toner cartridge replacements.
OS X 10.4+ is guaranteed to work with a printer that supports PCL or PostScript. Auto discovery via Bonjour/mDNS should work as well.
I have a Brother HL-L3230CDW. It's been great; rock solid reliable, reasonably priced consumables. I just tried connecting to it with my Quicksilver running 10.4.11. It was detected immediately via Bonjour in the Printer Browser utility. I tried the HL-2460 series CUPS v1.1 driver and it quickly printed a perfect page, but only grayscale. I switched to the HL-2700CN BR-Script3 driver and it also printed a perfectly in color, but a little slower. Overall, very easy to get working with only the built-in drivers.
I got one of these a while back and I could never get it to work with 10.4, even with drivers I found. What is the trick?
I mainly used it with 10.6.8 and newer, hooked up to my old A1186 Mac Pro, and my A1286 MBPs. Never tried it with a G3 or G4 Mac. Might be worth trying to use it with another Mac, running a newer OS, then connect to it using your 10.4.x Mac.
LJ 2100M. And an unusual failure. More like a slow motion nightmare. At a touch, most of the outer case cascade-shattered into small pieces like automobile glass. (Guessing the plasticizers *really* gave out.) That caused more things to displace. It seems some internal plastic hinges at the various covers and doors separated - and either no longer hang, or no longer close, or released blocking debris, or lost whatever piece that when closed informs the printer that its OK to operate. Something is even blocking the toner cartridge from sliding completely in.
Good to hear. Was unsure regarding PS/PCL interpreter vs emulator, and licensed vs clone. (There were some posts about Adobe apps in some Mac OSs requiring for clear printing a Generic Postscript driver (or maybe a licensed Adobe PS) which the Brother's version either didn't support or supported only in Windows.)
I have a Brother HL-L3230CDW... Quicksilver running 10.4.11. It was detected immediately via Bonjour in the Printer Browser utility. ... very easy to get working with only the built-in drivers.
