Hard to know. Recap and see. Also best to recap the logic board too.Ok, I can see that the mess is exactly on the other side of the PCB where the 8 caps are leaking. there’s still continuity between each pin of rows 1-2-3-4 and the corresponding pin. i.e. each row has 12 pins so I tested pin 1 of row 1 with pin 1 of row 2, then 3 and 4 etc... will recapping and cleaning be enough?
Incidentally, what is the continuity scheme?No - removing the PCB from the drivers is not necessary, but go spot-checking things. See what pins of 1 have continuity to 2 and 3 with a multimeter, and see whether 4 has continuity as well.
I was able to do the exact repair you did on a LM64P51 using a dead LM64P58 as a guide (there appears to only be minor trace layout differences between the two). All of the horizontal TAB bridge thingies are connected to each other on each pin and I just reconnected the one that wasn't.That panel is suffering from corrosion and you have a dead via to row driver #4. Stop running it to not make it worse. You'll need to recap it, or, if that has already been done, go over the work - carefully desoldering the row driver (which is a polyimide ribbon delicately bonded to the glass, and attached to the board by thin slivers of copper), and possibly running a jumper to driver #3 or somewhere else on the panel PCB. Look closely on this picture of a 145 panel which had the same defect - a pin on driver 4 has been jumped to 3 with thin wire for testing.
Excellent - glad that was of help!I was able to do the exact repair you did on a LM64P51 using a dead LM64P58 as a guide (there appears to only be minor trace layout differences between the two). All of the horizontal TAB bridge thingies are connected to each other on each pin and I just reconnected the one that wasn't.
