SevenTTY — local shell + terminal + SSH for classic Mac OS
Xero
I'd been playing with ssheven for a little while now, however it'd always been a bit buggy, the preferences file was getting corrupted, support for colors was pretty minimal and half broken, etc. After my recent adventure using claude + retro68 to hack up a system extension, I decided I'd try to fix up ssheven, and this quickly turned into "why can't I just make a full unix-style shell, too, like, port busybox or something to os7-9?" For many various reasons - that isn't really truly possible, however, what I came up with is essentially, an approximation of that.
Essentially, I've turned ssheven into a full blown "mac terminal" with a built in shell similar in feel to bash, and built in unix-like commands and syntax that wrap actual mac functions. For example, "ls -la" shows a file listing but where owner/group would be, it instead shows type/creator, "chown" can set type/creator, "chmod/chattr" can set lock, invisible flags, etc. It's got "ps" to show processes, "du", and "free" for disk/ram usage, including -m and -h human readable flags, etc. I've also added tab-completion for a lot of common operations, especially navigating files, and the built in commands.
I've also made "ssh" one of the commands, and you can now type "ssh user@host" and it will bring up the ssh login dialog that was previously the launch screen of ssheven, with the user/hostname pre-filled for you. You can also start a new ssh tab directly with command-s. Oh yeah, I added tab and multi-window support, too. It supports up to 8 sessions total between tabs/windows, mostly limited so it fits in 2mb, but this could be adjusted. I also have dark/light mode, and support for a "theme" system. Color support is now a lot more proper with all 16 colors, and I included some default dark/light themes that have much better contrast/readability than the old colors. Included in tools/ is a script to convert iterm2 themes to it's internal format. ".sttheme"
The name is a play on "seven" and "tty", though admittedly i've done most of the testing so far on os8.1 in qemu, same as the system extension I did prior. I'll likely try this on my real hardware shortly, but I imagine it should work just fine. I had to use up my half-off /fast mode in claude before midnight pacific to night, and this certainly ate up some tokens, haha! 68k and ppc versions are up on the github now.
That's awesome! I wonder if it would be possible to make it a terminal server as well as a client? (ie: ssh from linux to the provided interface).
Previously, I used the tool that let you telnet into an MPW shell, but I know that sshd would put significantly more load on the system than that.
I wonder how difficult it would be to add A/UX shell support (e.g. as an alternative to CommandShell).
the issue with adding proper unix shell support is that none of the unix subsystem really exists - no /dev/tty, etc. Instead, I tried to create "equivalents" but they are really more just conversions of mac functions into a shell-like experience. It would be kind of cool to make shell scripts work though - like create an actual sh/bash type language within it.
Any plans to add telnet functionality? It would be cool to be able to connect to BBS's with this.
i had a similar thought! Would also be handy to add netcat/nc type functionality for testing ports. Definitely on the TODO!
There's a new set of skills you learn to avoid said slop, like prompting for review, de-dupe, lots of ui/ux debugging, catching mistakes-in-motion or even making two LLMs fight it out on reviews. Having a good eye for things is still very necessary. It's got me back doing a lot more front-end design, which is something I normally don't do much of.
Can we ban ai :poop: already?
LOL if you'd talked to me a year or two ago I would have been similarly pessimistic about it, but this stuff is getting too good and moving too fast for me to avoid. Ultimately, it becomes about focusing on the end result, and not the process / academia, you are now the project manager, looking for a "done state" result that passes tests/QA, rather than the engineer worrying about code style. In that way, it's similar to dealing with a team of engineers.
Whether to use these machines should be a personal decision, but posting their outputs to a hobby website and saying you made them(!) is fair game for debate. I would at the very least like to see a tag here like in the trading post titles.
They literally state that they used AI in their post? They're not hiding it from you?
One of the reasons I hated AI initially was because I had people (in a professional setting, none the less) saying they wanted to make an AI version of ME, because I was apparently perceived as someone to emulate/copy. Once I actually dove in, it became a force multiplier for me. It doesn't have equivalent results for everyone, though, I have seen just as many engineers struggle to get the same results with it, and that's exactly the reason I think this is all a bit silly, because this certainly does just become another skill set to learn. There's a helluva lot of irony here that I wish you could all see, especially in light of my own experiences, but, the gatekeeping is real, no matter the hobby. AI or not.
Drama aside, I just pushed 1.0.3 with a whole suite of new features:
New commands:
  • telnet host [port] — opens in new tab with IAC negotiation
  • nc host port — raw TCP inline in shell
  • ping host — ICMP-less ping (TCP connect test) with 10s timeout
  • host name / host ip — DNS forward and reverse lookup with 10s timeout
  • ifconfig — show network interface info
  • open path — launch applications by path
New features:
  • ./AppName and /path/to/App execution from shell (strips ./, resolves paths)
  • 30-second connect timeout for telnet/nc
  • Cancellable connections (Ctrl+C, Ctrl+D, Ctrl+], Escape)
  • Right-Ctrl key support (QEMU compatibility)
  • Draw throttling for less flicker
  • Cursor visibility fix, Home/End keys, forward delete
I remember people saying using Photoshop was cheating and required no skill, as if just anyone could produce beautiful art just because they launched a particular program.
I've seen people do good and bad work with AI and like so many things, the quality lies with the operator, not the tool.
The thing that worries me about it is the confidence it give people in bad work, but on the other hand, I find the aggression and presumption on quality I'm seeing... Weird. It feels like smashing looms.
"That's fake! Its Airbrushed!"
"You Photoshopped that! Fake!"
"On that's clearly AI! Fake!"
Thanks for adding telnet support! Would it be possible to add the CP437 character set for better BBS ANSI emulation?
Ohh...I swear you keep reading my mind - I had similar character issues when trying to use claude through it (...to work on itself? lol). This is definitely on my TODO. I was hoping it wasn't something too difficult to tackle, I know when I was doing my retro websites for mac browsers, i had to just avoid unicode font characters, but i suspect cp437 within the terminal shouldn't be too bad. On the TODO for sure!
LOL, for some reason I'm imagining other silly scenarios as well, like: Kai's power tools is cheating! SuperMac Accelerator is cheating! Pure photoshop users only! Lmfao. I mean it's ironic in hindsight, given all the retro aesthetic stuff where people are like purposely trying to make things look like old vhs or old computer art, old cgi, etc. That itself has become an artform now.
I 100% agree it can give people false confidence, especially if you aren't naturally skeptical, because then it won't be, either, and you can build some stuff that's architected very poorly. If you lack deep systems-level understanding, the big picture stuff, so will it, because you won't know to ask it, and that's where I find people get big-headed about it's abilities, like, just because something works, doesn't mean it scales, or is cost effective, used the best tools for the job, etc.
I think people see the worst of it and think that's the only way it can be, but i'm literally using it for giving new life to retro stuff, which is almost the complete opposite of anything like that. Before I did any of this, I was prompting claude how to do IE5 CSS quirks for IE5 Mac, because I lived that era of browser hell, lmfao, but it's not like doing that manually is automatically a badge of honor, that's literally survivorship bias at it's finest! Hah!
