What I've received as of late...
Just got a bunch of stuff from @Mk.558 this evening. Another Quadra 650, which will be replacing the damaged Quadra 650, since this one works and doesn't need more than just swapping the extra RAM, the larger hard drive, auto-inject floppy, and other goodies I'd tossed at the damaged machine into it. There's also a Power Macintosh G3 (Gossamer beige minitower in the G3 Server configuration), a Q610 DOS compatible, some extra RAM for a post-NuBus PowerMac, a bunch of cards, some networking software and manuals, a couple 800K external drives, and another M1212 monitor that doesn't smell moldy, unlike the one I have attached to the IIfx currently.
Testing the Q650. Boots up and works correctly. Was surprised to discover that it has a properly working Quantum LP80S hard drive in it.
That is terrific! Very capable machines.
Agreed. Had that early 2008 8-core 2.8 GHz A1186 for a long time. Was my daily driver until I moved the Radeon HD 5770 video card up a slot and somehow caused the heatsink for the PCI bus chip to come loose. Became rather unstable at the time. Switched to the mid-2010 A1286 I owned at the time as my daily driver. Will be nice to have a Mac Pro again for my daily driver duties.
Picking up the A1289 later today. Have an ATI Radeon HD 5870 video card coming in the mail. Now need to hunt down a Dell UltraSharp monitor that works with both the G4 and the MP.
I still have the A1289 (Early 2008) I've had since new. I think I upgraded it to a Radeon HD 5770, but I still have its original Radeon HD 2600 XT, along with some amount of RAM I can't remember now (he special FB-DIMMs it require were stupid expensive for years, so I was stuck at 4 GB (which was adequate in 2009, but becoming increasingly cramped by even 2011 or so) until I was finally able to afford some used FB-DIMMs (I can't remember when or where I got them; might've been eBay sometime around 2013?)
It was solidly reliable for the most part (I took it to the Apple Store once because I thought it had a hardware problem; turned out it was a simple software thing that I might have done), and I only retired it in 2015 because it couldn't run newer versions of MacOS (OpenCore Legacy Patcher didn't exist then) (I had been running Windows XP on it for years until the "official" EOL in 2014 (had I known at the time that it was still receiving updates via the POSReady2009 hack (I only learned about it a year or two later), I would've kept it because I liked it much better), then I upgraded to 7 for the remainder of its daily driver status).
I was thinking of bringing it out of retirement a few years ago, but when I tried, it wouldn't work. Turned out one of the memory risers failed for some unknown reason. I got a replacement, and I *think* I installed it, but I never did anything more and it's been in it's box ever since (I got another, mostly identical spare unit about then and went with that instead because it was fully working).
c
You can spot Apple FB-DIMMs from the unique heatsink airflow design (and they probably need it since that RAM does get hot).
I quit looking for Pros a while ago because they were heavy to ship and people still wanted some cash for them compared to the dirt-cheap PC equivalents. I love the look of my G5's so I will eventually snag a Pro if I find one cheap locally. I think I have an Apple HD 4870 card here somewhere.
c
Ah, the A1186? Mine was almost identically equipped. Came with the HD 5770 video card installed. I did have to add an Airport Extreme card to it for Wi-Fi (have to do that on the A1289 as well). Had 6GB of RAM with, originally, my A1181's 160GB drive, then I installed a 500GB drive, ran that for a while, before I picked up the Seagate 1TB drive that I currently have in the A1289.
Keep your eyes on govdeals.com. I wouldn't be surprised if University of Ohio dumps a few on there. Currently, the University of Washington has something like 14 Mac Pros and one or two G5's up for auction.
Ah, right, the A1186! I couldn't quite remember what the number was for an Early 2008 and didn't feel like looking it up. Serves me right!
c
Just sourced a dual CPU tray with two 2.93GHz Xeons on it. Going to run it with the current 16GB of RAM split between the two processors, but will eventually add four more 4GB modules to bump it up to 32GB.
Sold the IIfx. Don't see myself having enough space to set it up, so off it goes. Also purged the A1278. In its place are two items coming. A 5,1 Mac Pro logic board to properly upgrade my A1289 and a mid-2012 A1286 MBP with 2.6GHz Core i7 processor and 8GB RAM, plus a 750GB hard drive.
The Mac Pro upgrade, successful.
The A1286... Another problem child. Worked well until I decided to try upgrading the RAM. Popped off the bottom panel. Was greeted with rusty screws and corrosion. Cleaned the gunk off with some 99% IPA and some swabs. Did the RAM upgrade. Put it back together. Looked like a PB180 with severe tunnel vision when booted. Set it aside for a while, after trying the other A1286's panel with it (stood both machines on their sides, then connected the old 1286's panel to the "new" machine's board) and having no luck. A couple days ago, tried a mini displayport to DVI adapter and was able to get video displayed on the Dell monitor.
Most recently, picked up an A1278 from uptekk on the 'bay. 4GB/1TB config, Core i5 at 2.5GHz. Will work well as a temporary MBP, until I find another actually good mid-2012 A1286. Did upgrade the RAM on it to 16GB.
