That card probably does not need a control panel. It isn't accelerated, looks like a close relative of the SE/30 VDR-2 card.Hi Alex,
Just bought Interware Vimage VDR-2G Video Card for Macintosh LC I & II w/ FPU Co-Processor. Looking for the driver. Any idea?
I have what I believe is the same setup:@Alex- Thanks, that was the driver! It is indeed nice to have the ability to use this card to it's fullest potential. Here are a few s hots of it running at 1024x768:
Forgot to mention I have a Daystar Turbo 040 installed and working great!I have what I believe is the same setup:
SE/30, System 7.5.3. Interware Vimage SE/30 24bit Video Card. I have found the Control Panel and installed, but no extension (INIT) or Slot Manager. Control Panel shows no Slots. Any ideas?
Thank you. I have the new control panel installed with no luck. It may be an issue with the Daystar Turbo 040 or its ROM version and the GrandVimage 24-16. Though, TattleTech can see the card in slot 9. Here are some screenshots in case anyone can help/verify. Thanks!@bregard -I have a GrandVimage 24-16 installed in my SE/30, which is an awesome video card. I have the GrandVimage control panel installed to control it, which includes the ability to turn on the card's video acceleration!
As for the VDR-2A, I don't think that they ever had a control panel for it (at least not one that I've found yet). I had to do some searching for the control panel for my GrandVimage, and I have uploaded the files for it on the Macintosh Repository:
Interware GrandVimage 24-16s v1.3.1 Video Driver - Macintosh Repository
This driver will work with the Interware GrandVimage 24-16 video card for the SE/30, and should (possibly!) work with other GrandVimage video cards...www.macintoshrepository.org
I currently have a Daystar powercache 68030 50mhz accelerator in mine, someday I need to try to get one of my 68040 accelerators to work with it.
OK, I think I got duped into the wrong card, Vimage SE/30 24bit vs. GrandVimage 24-16s. I may be stuck at 640x480 with no acceleration. If anyone knows how I can get my hands on the GrandVimage 24-16s I would GREATLY appreciate it. Thanks!Thank you. I have the new control panel installed with no luck. It may be an issue with the Daystar Turbo 040 or its ROM version and the GrandVimage 24-16. Though, TattleTech can see the card in slot 9. Here are some screenshots in case anyone can help/verify. Thanks!
View attachment 95549View attachment 95551View attachment 95552View attachment 95553View attachment 95554View attachment 95555View attachment 95556View attachment 95557
