Does anyone know if the 605/610 quaddoubler will work in an LC475? Tried it on mine but it will not chime or boot. I thought the architecture of an LC475 is identical to the Quadra 605
Yeah, it should work. The only difference is that the memory performance is a tiny bit better on the 605, but that wouldn't impact your upgrade. If you want to be absolutely sure, remove the little jumper next to the hard disk power connector on the logicboard and your 605 becomes a 475.
One question - is your 605 overclocked?
Edit - sorry, I see you have a 475. I got muddled. Same thing, just add the jumper to turn a 475 into a 605.
Ahh got it! Unfortunately it still will not chime with the pin and showing up as a Quadra 605 with the original 25 MHZ CPU. I guess maybe the 68040 on the quaddoubler is dead? Can I replace it with another 68040 or LC040 chip?
