Is the Quadra 610 Quaddoubler supposed to work in an LC475?
d3jsp
Does anyone know if the 605/610 quaddoubler will work in an LC475? Tried it on mine but it will not chime or boot. I thought the architecture of an LC475 is identical to the Quadra 605
Yeah, it should work. The only difference is that the memory performance is a tiny bit better on the 605, but that wouldn't impact your upgrade. If you want to be absolutely sure, remove the little jumper next to the hard disk power connector on the logicboard and your 605 becomes a 475.
One question - is your 605 overclocked?
Edit - sorry, I see you have a 475. I got muddled. Same thing, just add the jumper to turn a 475 into a 605.
It's not overclocked, just a stock LC 475 but won't boot with a quaddoubler. It does say 610-U1 on the gal chip though
Ahh got it! Unfortunately it still will not chime with the pin and showing up as a Quadra 605 with the original 25 MHZ CPU. I guess maybe the 68040 on the quaddoubler is dead? Can I replace it with another 68040 or LC040 chip?
You could swap the QuadDoubler's CPU into the LC's socket? To test it that is.
I can try! would that boot on a 475?
If it is an 040 with pins yes. The only ones that don't work properly are weird ones that you wouldn't expect in the QuadDoubler like the low voltage versions and the ones without a memory manager.
It should be a higher speed grade, but that only means you're running it way slower than it could go.
Let us know how it goes.
The CPU indeed does boot! running at 25mhz with a co-processor. That means something else on the quaddoubler is defective or just not compatible with the LC?
Possibly - I'd start by sharing high resolution, well lit, photos of the top and the bottom of the QuadDoubler. If possible natural light.
Attaching some full res pictures
It doesn't look too bad @d3jsp so I'll leave it to others to point out anything they spot.
Can you solder? The next thing I'd try is clocking the LC down to 20MHz. This means if your QuadDoubler was designed for a 20MHz Centris 610 and by bad luck can't handle a 25MHz bus, it will start working.
If that is the case, there might be better ways to speed up your 475.
Hmm, it doesn't work on a Centris 610 either, no chime. Maybe the gal or cache chip on the quaddoubler need to be replaced. Do you know if there are any clones for the GAL chip?
I'd be checking for mechanical damage first. Easier to fix and more likely. But not something we can help with very much over the internet. Most issues can be found with a magnifying glass and good light, the ones that can't are harder to fix anyway!
For what it's worth I have one of these Quaddoublers that came to me in a Centris 610 and it does work* in my Quadra 605 (basically same thing as LC 475). *Mine did not come with a fan so it seems to overheat and lock up the system pretty quick running at 50Mhz in the Q605, at only 40MHz in the C610 it's fine. When I jury rigged a fan (that wouldn't let me close the case) it would run stably in the Q605.
Hmm, weird. I don't see any physical damage on the board at all and the CPU works so it has to be one of the chips
There are not. If you want to send your card over my way I can take a look at it. I can crack most GAL20RA10s so if the chip isn't completely dead there's hope it can be read out. I do also have spare MC88915s in case that one would need to be replaced.
