Power book 180, power supply making tick tick noise
This part is the correct replacement, it’s significantly smaller in size than the original but can be made to fit:
thank you ... I will get about 5 of them and see how I go. So far nothing else is getting hot apart form inductor and this diode. I have busted power supply to make sure capacitors are ok. They seem to be, but I will replace them too
