I've just purchased a 1400cs/133 and it's lovely (other than the typical issues with a PC card door not closing and hinge cracked plastic).
I've read through everything I can over the last several hours but I haven't been able to figure out a good answer to this question:
What's the best way to network a PowerBook 1400 now (in 2026)?
As far as I can tell it comes down to 2 options:
Is there anything I'm missing? Any caveats?
I personally lean toward wired connections whenever possible because of speed and reliability.
Edit: I've gotten spoiled with SCSI drive emulators also providing emulated DaynaPORT and WiFi. It would be incredible is there was something similar for a 1400 but if there is, I can't find it...
- A PCMCIA WiFi card (Orinoco or compatible listed here), but all will require a dedicated WiFi connection to deal with the obsolete WEP security.
- A 3com EtherLink II or compatible PCMCIA card with a 3C589C or 3C589D chipset and dongle. It's difficult to find one of these complete these days and it seems the cheapest option is to buy them separately.
