Carrera040 & RominatorII on SE/30 compatibility issues
@falecore did you ever get it working? I am having type 11 errors every time I boot with bolles 040 card in my SE/30. I have a completely modded Mac with bolles riser, zigzagjoes 30 video HC, color LCD and power backplane. Motherboard is recapped and has new SIMM sockets, PSU is a modern replacement. I have a selection of custom ROMs a programmer and 128mb of RAM. Finally a BlueSCSI v2. The only thing I haven't tried is a better ATX power cable. Everything works beautiful unitl I plug in the card. On a very cold bit it'll load the OS for a minute and then type 11 crash. Reboots type 11 errors every time.
Unfortunately, no...... I was never able to get my Bolle Carrera 040 card to work.
Recently, I was able to test the Bolle Carrera directly, by plugging it into a IIci. Using the OG IIci driver, the machine still crashed at boot. Cannot remember if it was a freeze, or bus error, etc. WHatever it was, it was same as SE/30.
Just an FYI about my setup (Cant remember if I mentioned it) -
Recapped SE/30 w/ ZigZagJoe PSU retrofit. Tested with and without Rominator, tested with 8mb of working RAM. Also, I am using an older bolle mac con "topper card" with the newer Bolle 040 card + cache. The MacCon card tested working, I confirmed dip switch settings for all three cards and confirmed positioning of cards.
Just to be safe, I ran two new low gauge molex wires direct into the bus on the SE/30. Big props to ZigZagJoe for giving me direction on that.
Out of desperation, I also tried testing it in my 5 other refurbished SE/30's. Sigh.
Believe or not, I fairly certain that it's the Bolle Carrera card itself and not the topper card or MacCon card. I went over the card with the microscope and couldn't see anything out of sorts.
At this point, I am willing to mail it to somebody that would be willing to bench test for me.
It sounds like a similar problem to me. I do get a full boot, but after a few seconds it bombs with a type Ii error.
If you're getting the same issue in a Iici then I agree it's the card, such a shame. Have you had any joy contacting Bolle direct? I haven't so far.
Bolle offered as much assistance as they could, I am appreciative, although no luck getting it to work.
no luck, crashes even when plugged into my IIci
Does this not mean you can confidently send it back to bolle for repair or replacement? It looks like I may need to do the same.
That option has not been offered. I might first try and torture somebody this side of the Atlantic to take a look? Any volunteers? I would def hook up anybody who could get this thing working for me.
