Lisa 2/10!
It would just be my cost. I actually have an assembled external one with cable and 3d printed case for ~$24, a bit extra for the cable and connectors. I'd need to pick up another ESP board to put together an internal one, but it would be $20. Let me know if you're interested.
Unless prices have dropped, I paid ~ $13 for the assembled boards, and $6.50 for the ESP32s with ordering in bulk (5 boards), so it would likely be more expensive otherwise build your own.
Sent you a PM!
Hi Wottle, do you have any more ESProfile boards? A few specific part numbers specified by AlexTheCat aren't in stock at the PCB shops (though I think I was able to select equivalents), and the customs fees right now are a bit of an unknown. I just got my Lisa 2/10 booting from the LOS 3.1 installer 400k disks made on a Color Classic (vs an 800k drive system, but I did use 800k blank disks instead of HD 1.44MB blanks), and of course the internal Widget won't format correctly anymore. Thank you!
It looks like I have one internal and two external left. I need to flash the ESP32 board for the internal and then test, but message me if you're interested.
