Found this first Gen Apple LCD display for cheap. Anyone have one?
Going to try it out with a period correct (1998) Beige G3 Power PC I just picked up. Got it for only 20 bucks at the local computer recycler. Looks like people try to sell them for silly amounts on line. Anyway, we'll see how it works when the machine gets here. I may sell it, seeing what I can get, to fund other projects down the road, and get a less valuable display for the Beige G3, which reminds me of my old Performa. I just had the normal Beige CRT with that thing.
I also have one of these, and also the Graphite DVI version that appeared a couple of years later. I'm only missing the B&W G3 version that was identical to yours, sans the colour scheme and had a VGA connector instead. These are nice displays for the time! Yours is in much better condition than mine!
The extension post doesn't stay up except precariously all the way up, but other than that, in pretty good shape! will see how it fires up and works once my Beige G3 gets here!
The combination is up and running! But not sure I’m getting all I can out of the monitor. It doesn’t look like the settings are allowing me to use all the colors it can, and get as much brightness and clarity as I should be able to. I’ll read more and try to figure out more later.IMG_8013.jpegIMG_8014.jpeg
The ATI Rage from a Blue&White G3 is a decent upgrade for any beige G3, much faster than onboard and super cheap. The beige G3 SGRAM is harder to find these days.
Its nice, and scary like a portable;) mine also has a bit of that red hue, it dissapears a bit when its warmed up. I think harvesting some blue/white displays (sometimes i buy one for 15-20 euros) for spare panels would be smart
The combination is up and running! But not sure I’m getting all I can out of the monitor. It doesn’t look like the settings are allowing me to use all the colors it can, and get as much brightness and clarity as I should be able to. I’ll read more and try to figure out more later.View attachment 94267View attachment 94268
Looks like it might have a dim backlight.
What options do you get under ‘Flat Panel’ in the Monitors & Sound control panel?
You can pilfer one from a Rev. B to D trayloader iMac, or from contemporary (to the Beige G3) ATI graphics cards. But often easier to get a Rage 128, as you say.
Here is what I get when I do that.
And clearly something’s not right because if I walk away from the computer for a little while, and then come back, the display ends up, looking like this until I power it off with a power button and then power it back on.
Looks like this after I power cycle it. The display, not the computer.
Well, for 20 bucks, it was worth checking out and it at least works a little bit. I’ll be interested in figuring out if I can restore this.
Cool. What’s the Tracking button do?
Oh dear, could it be needing a recap?
Definitely worth it.
