Apple A/UX 3.0.0, 3.0.1, 3.1 and WGS95 1.0 (A/UX 3.0.1) and WGS95 1.1 (A/UX3.1) Image Files
As some of you know, I'm a bit of a fanatic when it comes to Apple operating system software, and specifically A/UX, which was not archived fully when I got into this hobby 4 years ago.
I had endeavored to source original CDs and disks to image and archive, because many of the images online were partial, corrupt, not original (edited), etc. Only through sourcing original media and archiving them using proper methods and tools can these things be properly preserved in their original unaltered format.
I have succeeded! I have personally archived and uploaded original images from A/UX 3.0.0, 3.0.1, and 3.1. Through this, I have found that there are differences between the same version of A/UX shipped as a "retail" product, and bundled with the Workgroup Server 95 (WGS95).
As such, I have differentiated them in my uploads. The archiving and preservation of 3.x is nearly complete. Only missing is a set of images from 3.1.1, of which I do not know if they exist on their own. I've never seen them.
My work on this project is basically concluded. You can access all of my original image uploads from the Macintosh Garden, page is here: https://macintoshgarden.org/apps/apple-aux-300-and-301-wgs95-reference-archive
Thank you to those who helped me with this project. A special thanks to @slomacuser for selling me things I needed to achieve my goal of having a complete set.
My 2.0.0 and 2.0.1 project can be found here: https://macintoshgarden.org/apps/apple-aux-200-and-201-reference-archive
I have been told some of the images in the 2.x archive are bad. I haven't gotten a way to test them out still. However, there are many images in a variety of formats, and from all of them there should be at least one set for installation. If anyone wants to verify quality of those images and provide feedback, please do so.
As for 1.x, several copies have turned up in the past few years on eBay only, and sold for $1400+ each time. None of them have been archived and uploaded. I feel this will likely never happen, at least not in the foreseeable future. If you have original media for A/UX 1.x, please reach out to me!
All the best! Signing off...
also hey if you need to test it, you could, i guess, try out shoebill, though it is very old and buggy, and you would need to create a preinstalled hdd using a very specific method in qemu-system-m68k. still, good job!
Based on our recent success running System 7.0 on New World Macs, I've been wondering if it's technically possible to tweak the ROM so that A/UX 3.x will also run on New World Macs. Haven't had any time to dedicate to investigating this yet though.
This is very unlikely to be possible
So was running System 7.0 on a G4 Mini, but it happened. There may be timing issues, but it looks like the proper environment can be fully defined in the ROM, and everything run through the 68040 emulator. This of course means running A/UX 2.x and lower would likely be totally impossible unless someone wrote a new emulator layer, but the current CHRP logic seems to do a decent job at presenting new world Macs as 68k Macs to older OSes.
But A/UX doesn‘t really base itself on the ROM. It is a completely different OS. The PowerMac ROMs were designed to specifically emulate the 68k part of Mac OS so it is not very surprising you can run a 100% 68k Mac OS on a PowerMac. But this doesn‘t mean it can run an arbitrary 68k OS. You will at most be able the boot the „bootloader“ System 7.1 and then you will likely fail with a „no FPU“ error.
A/UX has its own drivers for all of the hardware and does not use any of the ROM drivers. There is zero chance of making it run on New World.
Well, maybe not zero, but it is indeed some infinitely small number.
in 1991, about the time of the A/UX 3.0 release, Apple had announced a PPC-compatible release, referred to as A/UX 4.0, which would've been re-based on AIX (a variant of which shipped with the ANS). Of course A/UX 4 never saw the light of day as it was cancelled in 1995 due to the ongoing turmoil within Apple, but I wonder if any early development builds of it exist, a la Copland?
c
Even though A/UX 4.0 started development, it was never released outside of the developers working on it. I have yet to see or find any reference to build numbers, build versions and notes, working names, etc. Nothing. So it likely fizzled out even worse than Copland did.
If there is any A/UX 4.0 internal builds out there that can be archived and tried out, they likely work on a very specific set of hardware.
And just because an A/UX 4.0 internal build exists, doesn't mean it's possible to make 3.x work on PowerPC. A/UX 4.0 would have been a complete re-write of the entire OS. Like what Copland was. That means that comparing A/UX 3.x to 4.0 is akin to comparing System 6 with System 7, or maybe even 7.6 to be more accurate. I wouldn't expect to be able to run System 6 on a PowerPC Mac, and for the same reason, I wouldn't expect to be able to run A/UX 3.x on any PowerPC Mac.
But... I'd love to be proven wrong. The original good install media is out there, archived, and ready for someone to try it out. Just remember, A/UX 3.x only works with 512 byte per sector disks and drives.
