Just in adding, as there is no way to edit this past the Time Limit...
A few members have washed their logic boards in tap and filtered water and ended up with a board covered in this fine white dust that was difficult to remove. Sometimes it interfered with the board, other times it did not as different posters live around the world and their water contained different minerals from others.
For the keyboard mask, depending on where you are, the minerals in your water may or may not react with the painted conductive surface of the mask, with a high chance of it reacting. Why risk it? Better to spend the extra $2 - $3 on getting a couple of gallons of distilled water from the dept. store.
