Powerbook 100 - Recapped LCD and Logic board but screen is"blobby"
why would you bake it?
it looks like moisture or oil on the BACKLIGHT
see image. behind the LCD is a diffusing film and then an acrylic lightguide. these two parts are sensitive to oils and solvents. you likely got some kind of liquid in between the diffusing film and lightguide.
ask me how i know.
you have a few options here.
  • you can attempt to clean the film and or lightguide with a microfiber cloth or something (hey it's already mottled, can't get any worse)
  • you can purchase a new film or lightguide from aliexpress and cut them to size
  • you can find someone with a bad LCD (bad polarizer, display lines, impact marks, cracked glass, etc) and swap the good backlight over
the positive thing is... the LCD itself seems in good condition... so you're halfway to a perfect panel.
I agree, looks more like the backlight diffuser got liquid contamination somehow rather than vinegar syndrome. Should be plenty of supply of dead panels to swap those parts from.
Fortunately I actually have one but I'm not certain that screen is toast bc I haven't recapped it yet. It has some pinstripes but in my experience that's not typically damage... Anyway, my first move will be to attempt to clean it and then dry it - this kind of screen repair is a first for me. I'm fairly sure I'm going to screw this up :)
I’ve had this same problem (to a much more minor degree) on my PowerBook 540. I found the acrylic sheet was permanently stained and could not be fixed. Maybe your case is different, but I wouldn’t count on it. Worth a shot in trying though.
Bummer ok - next step is clearly baking :)
how the heck did you arrive at that conclusion?
when did anyone here say bake?
this repair might be beyond your ability. i recommend passing it on to someone else.
It was me trying to be funny (and failing) hence the :) face. People bake the 180 LCD at super low temp to fix the tunneling issue. I'm certainly not going to cook the film - im about 50/50 right now that I screw this up anyway - just not that way.
just be careful and be patient. wear nitrile gloves if you're not comfortable.
you already have half a working display, you just need half of a broken display.
There are lots PB100s with degraded displays (pink bloom around where the trackball rests under the LCD causing small fractures in LCD over time. As yours is a good display without this, I'd look for a junk PB100 and retain all the polarizer films etc. and transfer over
