G'day all,
I have this iBook Clamshell and I did logicboard swap, I had 466mhz board & DVD drive from very brittle/cracked body - into 366mhz unit. The 366mhz unit is Lime iBook and the Logicboard is from Graphite body.
From memory - I knew it'll boot up unique GUI interface to match the body colour ie. Lime iBook will boot with green background interface, blue will be boot into blue... Same what iMacs used to do too.
But this one - it'll boot in Blue instead of Lime....
For some stupid reason I recall there is either firmware coding or software to change the colour in the firmware - what was it?
Thank you
Cheers
AP
Thank you
Cheers
AP
