unfortunately they also need recapping. they have SMD caps on the main board of the SONY drive.One of these guys mixed in with the random stuff
AppleCD 150
AppleCD 150
LOL wouldn't that just be the case??I was checking it out and theres a label on the bottom that says "1.1 GB/20 MB - Bad Screen"
So we're now in the same boat Lol it probably shit out when it was new and spent 30 years in that Duo Dock.
Is it possible to still use the laptop with the Duo Dock?
Is this a decent laptop?
Any other recommendations?
I found an Apple ImageWriter II, Apple Stylewriter, Apple Personal LaserWriter LS, and an Apple Scanner. No cords for anything and the stylewriter is missing the tray(s) its just the body.
Worth keeping?
depends, do you find printers or scanners interesting?Worth keeping?
This one and the original StyleWriter need to be recapped ASAP or the boards will be gone beyond repair.One of these guys mixed in with the random stuff
AppleCD 150
I wouldn‘t be too sure about that. I have three of them and they still work great. You can get aftermarket cartridges (Canon BC-02) easily and since they include the print head, you‘ll have a good chance of getting it to print with little work.StyleWriter II will be all gummed up and probably not work.
Everything does. I did plug it in to the wall and turn it on to see what would happen it seems to work good. The light was green and it ejected a square plastic tray out that you put a cd in, then i push it back in there and the light gos yellow for a minute while its doing its thing then green again. Then it spits the tray back out, i didnt put any cd or anything in it or have it hooked up to anything. But the ejection mechanism sounded great. Where I live doesnt get very hot so that could have played a role in these systems and devices' caps lasting a few years longer than they would somewhere else in the country. At least thats a hypothesis I came up with lolunfortunately they also need recapping. they have SMD caps on the main board of the SONY drive.
Just gently bend one side of the metal chassis out until one side of the board swings free. I've seen exactly that in the install instructions for other compact Mac upgrades.Ran into the first thing thats stumped me so far. Took apart the SE with the radius card in it. Trying to get the logic board out but theres a card on top of it that the radius card plugged into, and the socket is hitting and wont let me pull the board up. I dont know what to do ive look all around for something to take off etc. I was about to just bend the brackets as it looked like someone already did that at one point they are bent lol.
What to do?
I knew this had to be the way but i thought how could that be the official method lol. Going to do it now thanksJust gently bend one side of the metal chassis out until one side of the board swings free. I've seen exactly that in the install instructions for other compact Mac upgrades.
But all you have to do is change it right? What do you do for a battery? Did you solder one in or just buy a holder similar to the one I got? What is the normalRunning without a battery is annoying because every time you boot the machine, the default mouse speed is super slow.
I just found it browsing ebay one day for my IIgs i figured it would work the same. Would be cool to have it outside of the case too so you dont have to open it up. But then again it takes a few minutes to open it up, think ill just leave it inside as im keeping it anyway. Would be a good solution for someone who didnt want to ever tinker with it. Thanks for the helpYep. I soldered in a holder on my SE, but I enjoy soldering. The holder in your pictures looks like a pretty slick solution. That's the first time I've seen it done that way.
