I assume you took a look at the phase 2 training material on the AppleTalk for Programmers CD? You need to install Macromedia Director to view it (SN on the installation disk image). There is also the Apple LAN Literacy CourseNothing has come up at all in my searches. Now that slide deck has something that might have been mentioned in the original document. Namely the overview of the algorithm for a node to bootstrap determine its network address.
If you are implementing an AppleTalk node or router, you must have this document. Simple as that.
Too bad a bunch of us bidding pennies for the document wouldn't have any effect! Getting these documents digitized secures a significant piece of usable history.There is a copy of the APDA document
on ebay right now I'm going to try to buy.
Please don't bid against me.
I had to pay a fsck-ton of money for the AppleTalk PC APDA document and I'd rather not go
through that again.
