Anyone got a spare Beige G3 ROM?
Going back to the title:
Anyone got a spare Beige G3 ROM?​
Does it matter what colour the ROM is?
Bah-dum! Tishhhh!
Don't PCI graphics cards run out of their own driver in the card's ROM? I guess there could be a bug in some base OF word in Rev A that messes up the card's OF driver though.
With a Radeon 7000 installed, two weird things are happening:
- With a monitor connected just to the Rage Pro, after the desktop loads the system will crash with a green screen or no display.
- If one monitor is connected (either to the onboard graphics, or the R7000) it will not show the happy Mac or the early stages of the boot process. It’s behaving as if the primary monitor is the secondary, whichever graphics card it’s connected to.
None of this occurs with the Rev C ROM.
Yeah, there are known issues with that era of drivers. They sometimes conflict with other ATi cards. The 6500 is an example. ATi PCI cards don't seem to work because the built in Rage II causes issues.
Ah, do you think the Rev A G3 ROM might share some of the bugs that afflicted the 6500?
For the ATY,mach64_3DUPro, The older ROM has version 1.49 while the newer ROMs have 1.53.
Maybe it’s the 1.49 version of the ‘3DUPro’ ROM that’s buggy in that case. All Beige G3s with a Rage Pro would have shipped with a Rev B or C ROM fitted (right?), with the version 1.53 ROM. So I’m presumably using an unofficial combination.
This could be software driver issues. Given you get to the desktop. Try different versions. The ATI drivers for classic Mac OS are a nightmare. Sometimes the crash when the extension loads, sometimes they pause for a minute when they reach the desktop and other stuff.
Do you have the apple version of the driver installed (not visibly ATi branded)? That might be a conflict if you have both.
That's not a huge deal, you can usually muddle through by connecting two monitors, changing the settings, then disconnecting one.
This is probably because it thinks two monitors are connected. Other people have mentioned this.
I found a pic of this ROM which I suspect to be Rev B, chips are marked 341S0455/341S0456.
@trag was asking if the Rev C ROM adds any new features. I believe it adds support for the Bordeaux DVD Personality card, this comes from an Apple tech note.
There's mention of a rev 4 (version D) with checksum 0x78eb4234 but I only have 0x78e842a8 so I don't know if 0x78eb4234 is real.
Perhaps that was an unreleased prototype revision that was scrapped in favor of the B&W?
There was some discussion of the elusive Rev 4 ROM awhile ago (earlier this year?), and I think that was the general consensus.
c
Right. That discussion is where the 0x78e842a8 checksum ROM came from.
https://68kmla.org/bb/index.php?threads/the-820-0961-a-mystery-g3-3-3v-flashrom.48746/post-548625
And it mentions the 0x78eb4234 checksum ROM.
https://68kmla.org/bb/index.php?threads/the-820-0961-a-mystery-g3-3-3v-flashrom.48746/post-547621
The checksum refers to the checksum for the first 3 MB of the ROM. There is another checksum used for the entire ROM elsewhere. The Serial Test Manager has a test that performs the checksum for the entire ROM.
https://68kmla.org/bb/index.php?threads/the-820-0961-a-mystery-g3-3-3v-flashrom.48746/post-548608
The algorithm for the entire ROM checksum may be in the DiagnosticsGossamer.s source file.
https://68kmla.org/bb/index.php?threads/skipping-the-startup-memory-test.50699/post-571099
I should look into that algorithm and add it to my rom lists for ROMs that use it.
