Yes, I get it, Eric from BlueSCSI dev said the same, so... let me give a better description of my symptoms with this card as is right now.
The card requires the ID for the drive to be 6 (if you want more than 1 drive) or its ok with it as 0 if you want it to auto-boot. Once I have multiple drives on my BlueSCSIv2, it requires I use ID6,5,4 etc and I HAVE to use pr#7 (the SCSI card is in slot7) for it to boot. ID 6 is the drive that gets booted.
Once it IS booting, it complains that there is no SCSI driver for the card. Suggesting it HAS recognised its a SCSI card, but for some reason the stock IIgs driver wont dance with it.
I boot into GSOS and the single drive on ID6 appears as the boot drive BUT no other drives appear in the GSOS desktop. Using Advanced Disk tools gives another driver moan, and it then WILL NOT do anything with device 5, 4 etc.
Now IF I use SCSI Util disks from Apple, and I boot them, they DO show devices 6,5,4 and will even allow me to partition drive 5 into 3 partitions. Once I do this however I can never get the machine to boot again, even IF I use pr#7. I can only get this working again by deleting the files for ID5 and 4.
So... the default GSOS driver does NOT see my SCSI drive, even though I assume these drivers were written specifically for this Apple SCSI card (originally). I'm using the GGLabs Rev1 (clone) card that gives no mention of special drivers though, so...
Makes me wonder, did the GGLabs Rev1 cards ever work? And for now Mr GGLabs, the vendor is still AWOL. Its quite a lot to spend, $159, for a card that appears to be junk. NOT impressed.
