I just set up my Plus and found that the system no longer recognizes the mouse button. I checked with a meter and confirmed the button is functioning properly. I recently had the machine apart and had the logic board out to install the diode needed to power the external SCSI port and found the diode had already been installed, so I put the board back in. I did not do anything else with the logic board.
I haven't taken the logic board back out to inspect it yet, before I dive into this I just wanted to see if anyone knows of any common failures on a logic board that can cause this problem.
