I’m working with a Mac SE that has a Radius SE Accelerator 16 installed. Connected to it via the MagicBus expansion slot is a Radius Two Page Display card—this is the version with the single BNC connector for monochrome video out.
The ROMs on my TPD card are version 3.0, and as far as I can tell, the drivers that work with early firmware versions 3.0–3.3 appear to be completely lost. All currently archived RadiusWare installers require ROM version 4.4 and will crash or fail to load otherwise.
I’ve seen ROM images floating around labeled as being for the Full Page Display—specifically version 4.4—but I’m unclear whether these are actually compatible with the TPD card. Some Radius documentation seems to suggest the same driver/ROM branch covers both cards, while others imply the TPD and FPD use separate ROMs and timing logic. Radius even stated in some Q&A docs that the FPD interface can't be used with a TPD monitor, which makes me cautious about flashing FPD ROMs blindly.
Has anyone successfully upgraded a TPD interface card to ROM 4.4 and gotten it working with the SE Accelerator 16 under System 7?
Were you able to use the commonly available "FPD 4.4" ROM images to do this, or did you need a different dump specifically from a TPD board?
