Hey, working to troubleshoot my simasimac Classic after doing a recap of the logic and analog boards and trying to repair damaged traces. It's coming to the point where I think I need to start measuring voltages on the board and trying to hook up a scope - it's become a nightmare of lifted pads and corroded vias.
First option -- how can I get my hands on an extension cable for the 14 pin mini-fit jr cable? I don't have a crimper, but would get one if it's truly the only way.
Second option - I have a Siglent SPD 3303-C triple output bench supply that I use for building synthesizers, but I've only ever used two outputs in a simple +/-12V configuration. Can I use this bench supply to power the logic board? It has a third output that is statically set to 5V. Assuming I set output 1 and output 2 to 12V each and bridge output 1's positive and output 2's negative terminal, would I just connect a jumper from output 1's positive output to the negative jumper of channel 3 to get the voltages I need? I bought a J12 breakout from Joe's Computer Museum thinking that perhaps I might need to do this at some point.
