Well, now I have a new item to hunt for and some new hope haha. I'm assuming there is some sort of board inside them that needs to be saved?
The 'nub' issue is an important one as cases often do not have any clearance. I rebuilt a PB 145b battery but had to send back the batteries initially sent. They listed as 'flat' as they were not truly flat. Company was good about it and found truly flat NiMH for me. For that matter, AA battery diameters can be different - companies should list the full specs for any battery as nothing screams frustration better than a glued case that won't slide into the device, because it is very slightly bulged (aka my Newton 2100 battery rebuilds).I have them tack-weld on tabs, and then I solder the tabs to bits of the old ones. I really should get the welder as well, but it worked ok for me. Here is how the packs looked side-by-side. You can see the tabs they put on with some length. I trimmed them up and then soldered as necessary in the second photo. One more important thing I ran into: make sure that the cells DO NOT have the protruding nubs from the positive side. If they do, the cells will not fit inside the battery case. They need the flat positive and negative ends.
View attachment 63856 View attachment 63857
But this thread is about the 3400c, which is the machine I’m referring to.These still work well long-term for the 1400.
My apologies. Seeing all my posts, I thought it was a parallel 1400 thread that is out there.But this thread is about the 3400c, which is the machine I’m referring to.
Hey there. So what ever happened? Were you able to get working 3400 batteries again?Good luck. I have read that some have tried to prevent the BMS from bricking itself by maintaining power using external power, but did not work. Should have... but did not. Not sure why Apple did this, as other LiON models can be rebuilt. I have a couple of NiMH packs for 3400 waiting to be rebuilt but they take 12 pcs HR-4/3AU NiMH cells that are twice as expensive in comparison to regular 18650 LiON cells. And of course they have to be ordered and not kept in stock. Good I can hurry up and wait.![]()
Does ANYBODY have a pinout/wiring diagram for the 3400c battery? I'd like to try rebuilding one.I have a 3400C coming in the mail with a barely alive battery, and want to know if there’s a way to rebuild them currently? If not, is there places where I can find NOS batteries that still work?
Is this confirmed? I tried a 5300 battery in a 3400c and it wasn’t detected.They work in the 3400c
