Well I guess each to their own and all that and no, no I’m not.I don't like when people leave big empty holes in cases... You've got those NuBus slots and power supply orfices wide open. Grinds my gears!
Are you going to spray paint your keyboard, mouse, and monitor silver next?
I simply cut a big hole across the ports with a cutting disk, the id is normal 840av as I’ve put a jumper on the led connector
being a broken motherboard in a draw.
It’s the same one, been out of sorts to do anything macintosh for a while mainly due to life, moving house etc, and giving this a spruce up with the picopsu has helped get my mojo back.This is your second 840av in a IIci case, right? Cause you had one at the meetup.
Great for bench testing, say, a problematic graphics card.one of the best cases - good choice
