M2785 rebuild
Hi folks,
My Powerbook 5300CE's AC adapter just kicked the bucket. It's outputting random voltages, none of them even getting close to the required voltage to power the machine. I was therefore wondering if anyone has attempted to rebuild one of these (I assume it requires a recap), and what is required to get it going again?
Thanks in advance for any advice.
For safety reasons, rebuilding a power adapter would not be my first choice. If you so wish, a good quality universal power adapter with a 24 V DC output at 2 A with an appropriate connector (barrel type with centre +) could be an alternative.
Why's that? I've done multiple desktop PSUs, so I can't see why doing a laptop one should be an issue?
My 1400 adapter gave up the magic smoke a few years back. I bought a replacement from power4laptops.co.uk about 3 years ago and it works great. They don’t look anything like an OEM adapter, but that doesn’t bother me personally.
Looks like they make a 5300CE variant also:
Granted, if you’re in the US I don’t know how the new tariffs might affect the price.
A recap might get it working again. There's one hidden screw under the label, then you can put the brick into a vice and bust it open. Mine opened fairly cleanly.
Thanks, but that's a bit outside of my budget. I'll keep it in mind though.
Is the glue in these able to be softened with a hot air gun? I have a 5300 psu that I'd like to do at some point also...
It’s not glued shut, it’s ultrasonically welded. So that won’t work unfortunately.
That's not so bad - engineered USW joints generally have a few sharp edges around which to fracture cleanly...
I'm guessing on your one it left an easily glue-able fracture line?
