I've got Mac Plus that I'm working on fixing up. It boots and runs just fine from floppies. I've got a SCSI2SD adapter plugged into the SCSI port in back. I've formatted the SD card using Lido 7.56 with a single 2GB (max size) partition at 3:1 interleaving. The Plus sees the SCSI2SD just fine and can read from and write to it. I installed System 6.0.8 on the SD card from a set of floppies. However, the machine will not boot from the SCSI2SD. It simply sits at the flashing disk screen forever.
I also have a Mac II which boots from the (same) SCSI2SD adapter and card without any trouble at all.
Has anyone seen this before? Any ideas about a possible cause? Why should the drive work fine when booted from a floppy but not be bootable itself?
Thanks!
Thanks!
